different ways on making a port channel
robertkwild
hi all,
whats the best way on making a channel group is it -
conf t
int range <g1/0/x-x>
switchport mode trunk
switchport trunk allowed vlan add | remove <ID>
no shut
channel-group 1 mode auto
or -
conf t
int po1
no shut
thanks,
rob
luis_cordova
Hi @robertkwild
In my opinion, of the two options you indicate, the only valid is the first.
In the second option, at no time do you indicate that the g1/0/x-x interfaces are part of the channel-group, so it will never be part of the portchannel1..
balaji.bandi
int po1
shutdown
no shutdown
Once both the side confifured and check the config and
int po1
no shut
to be safe
BB
