diffserv and qos
carl_townshend
Hi all, is diffserv the layer 3 marking of the packet, whereas 802.1p is the layer 2 marking ? and do we have to map these at between the layer 2/3 boundaries ?
5 Replies 5
kerek
Level 8
Level 8
Yes the .1p is used within layer2 frame (only in tagged frame) and DSCP and ToS is used within IP header. If you want to preserve the layer2 marking you have to map it to layer3.
Hope it helps, if so pls rate
Krisztian
when i set the qos value on my switch for the port, If the pc or device does not set its own value say for a paticular application etc, how do i make the switch apply the qos value to the traffic to the incoming frames ?
The best way is to apply a policy-map on the ingress interface and classify (based on acl) and mark the packets (set cos, dscp).
This link fairly good describes how qos should be configured:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&type=Subscriptions&loc=.1dde8945/1&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing
Hope it helps, rate if does,
Krisztian
Carl,
If your switch supports the features, then you can always classify the packets based on IP address, port no etc, at the ingress and mark them as required.
eg. on a 3750 switch
ip access-list extended VOICE
permit udp 100.100.100.0 0.0.0.127 any range 16384 32767
class-map match-all VOICE
match access-group name VOICE
policy-map VOICE-ACCESS
class VOICE
set ip dscp ef
interface fa 1/0/1
service-policy input VOICE-ACCESS
HTH, rate if it does
Narayan
thanks for your help, I know im a pain but could you explain what each line does? so all we are doing here is creating an access list that defines port number etc, and if there are any matches it applies the ef policy to them? also say if we have a phone that already marks the packets, what would we do here
again , many thanks
Carl
