direct connection not showing connected
jclj
Trying to build up a test lab. I have three routers connected via serial cable.
Router 1---------------------
10.20.20.10               I  10.20.20.11 s1/0
                              Router 3
                                 I  10.20.21.11 s1/1
Router 2---------------------
10.20.21.10
All have a subnet of 255.255.240.0
Only When I do a "show ip route" i get:
     10.0.0.0/20 is subnetted, 1 subnets
C       10.20.16.0 is directly connected, Serial1/0
                   is directly connected, Serial1/1
C    192.168.1.0/24 is directly connected, FastEthernet0/0
Why am I not getting Serial 1/1 to show as "Connected"
You need a static route to ping R1 from R2.
Regards.
Alain.
jclj
ah, figured it out. had to interfaces on the router within the same subnet range. I changed serial 1/1 to have an ip of 10.20.33.11 and it showed as that subnet is connected.
I would have thought I would have been able to ping Router 1 from Router 2 after I got the link "connected". Does this not populate the tables to do this?
Regards.
Alain.
