Flapping between Router(2811) and Switch(2960)
harizmthaha
we have cisco 2960 switch which is connected to a cisco 2811 router.
Anyone can help to fix the flapping issue between these two devices??
The following actions i have taken, but no result..
I have changed cables.
have set speed to 100 and duplex full on both the interfaces but the interfaces are showing up up still not getting connectivity..
same i have to auto on both sides still no result
what configurations should i set to resolve this issue...?
Hariz
10 Replies 10
bhargavdesai
Does ports on both side shows down on interface status...?
Can you paste the configuration of Both ports....?
I hope you have tested the cable MIDI MIDIX....
any log messages....
Bhargav
conf t
int f0/1! example
switchport none
switchport enca dot1q
sw mo trunk
speed 100
duplex full
end
wr
Let me know if layer three is involved on one of the two
Alessio
Bhargav and Alessio
Here's the configurations on that particular router and switch interface..
ROUTER INTERFACE
interface FastEthernet0/1
ip address 172.16.41.1 255.255.255.0
duplex full
speed 100
  FastEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0021.5589.1c69 (bia 0021.5589.1c69)
  Internet address is 172.16.41.1/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:27, output 00:00:02, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     9262 packets input, 2002840 bytes
     Received 271 broadcasts, 109 runts, 0 giants, 0 throttles
     129 input errors, 20 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     13500 packets output, 9195662 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
SWITCH INTERFACE
interface GigabitEthernet0/24
description *** LINK TO ROUTER ***
switchport access vlan 2
switchport mode access
GigabitEthernet0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0021.1c0f.5598 (bia 0021.1c0f.5598)
  Description: *** LINK TO ROUTER ***
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive not set
  Half-duplex, 10Mb/s, link type is auto, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:31, output 00:00:01, output hang never
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     22985 packets input, 11141288 bytes, 0 no buffer
     Received 5196 broadcasts (0 multicasts)
     0 runts, 41 giants, 0 throttles
     643 input errors, 468 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 4182 multicast, 0 pause input
     24865 packets output, 4151183 bytes, 0 underruns
     0 output errors, 79 collisions, 1 interface resets
     0 babbles, 36 late collision, 0 deferred
Hariz
Hi Hariz,
Your output is showing that G 0/24 on your switch is 10/half.
When you say it is flapping, are you saying that the line protocol is going up and down?
-vg
As Vincent said ....
SWITCH INTERFACE
ROUTER INTERFACE
You should Hardcore both side with Speed and Duplex.
So put both the port on 100 Mbps Full Duplex
Speed 100
Duplex Full
H2H
Bhargav
  Vincent & Bhargav..
I have checked likewise too as i already told u in my first post..
there's no change still the port is showing up up
Hariz
Hi Hariz,
What is the IOS and device exact model on both the devices. Let me check if there in known issues and workaround for the same.
Also let me know
If this is directly connected or through backbone???
Have you tried connecting your laptop/pc to both the switch and router interfaces????
to identify the bug is only with the complatability between those 2 devices or someother problem.
Please do rate if the given info helps.
When you set both sides to 100/full, what is the output?
I have ran into some issues between a cisco router and an adtran router where it wouldn't negotiate correctly.  Even hard coding it didn't work.
Vince
Vincent,,
When its flapping, the line protocol remains up and when sets 100/full on both sides its still up but not geeting connectivity..
Karthik  here's the version details:-
SWITCH
------------------ show version ------------------
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(37)SE1, RELEASE SOFTWARE (fc1)
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
System image file is "flash:/c2960-lanbasek9-mz.122-37.SE1.bin"
cisco WS-C2960G-24TC-L (PowerPC405) processor (revision D0) with 61440K/4088K bytes of memory.
2 Virtual Ethernet interfaces
24 Gigabit Ethernet interfaces
64K bytes of flash-simulated non-volatile configuration memory.
Model number                    : WS-C2960G-24TC-L
Switch   Ports  Model              SW Version              SW Image
*    1   24     WS-C2960G-24TC-L   12.2(37)SE1             C2960-LANBASEK9-M
Configuration register is 0xF
ROUTER
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(9)T7, RELEASE SOFTWARE (fc3)
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
System image file is "flash:c2800nm-advipservicesk9-mz.124-9.T7.bin"
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
2 FastEthernet interfaces
2 Serial(sync/async) interfaces
2 Low-speed serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
rgds
Hariz
When you hardcore both side with Speed and Dupex it is also advisable to put Nonegotiate on both side.
I would also like to know
"When its flapping, the line protocol remains up and when sets 100/full on both sides its still up but not geeting connectivity.."
How you check the connectivity. Do you find anything in LOG.
H2H
Bhargav
