Disable classless routing on switch
Mokhalil82
Level 4
Level 4
Just need some advice. We have 2960x switches and as part of a security audit we were asked to disable classless routing.
The swiches have been upgraded to the latest IOS release but the 'no ip classless' command is not available.
The switches are L2 but have ip routing enabled with a default route.
I understand the ip classless command may not be playing any role in this situation but for the audit can i disable it on these switches.
0 Replies 0
