disconnect device on switch
coskun sanli
Hello
I have 4 devices about the light system and these device connected cisco 2960 switch
I can access these devices (ping ), after some time  I cannot access
I see "switch port up and connect on 2960 switch"
if I use dummy switch these devices never disconnect and every time access
I tried no cdp neighbor , speed 10 , no auto-negotiation
can you share experience or advice these situations
7 Replies 7
Hi, can you check the log of the switch (show logging)?
Can you check if the port go in blocking due to spanning tree (show spanning tree summary)?
Regards.
mkazam001
Level 3
Level 3
test with a minimal interface config
also try speed auto, duplex auto
could connect a test laptop to one of those same ports & check if it stays connected
regards, mk
Hello
I tried speed auto and duplex auto, spanning tree
these devices connect to new 2960 switch and there is no config, the port is up but there is no ping
i check log but i didn't see anything
I am sure these devices never disconnect on dummy switch
Hello
@coskun sanli wrote:
Hello
Do these devices obtain ip address allocation via dhcp or are they statically assigned?
On the access ports do you have spanning-tree portfast enabled?
Could you try the following
default int x/x
int x/x
switchport host
power inline never
<if poe switch>
shut
no shut
Kind Regards
Paul
Hello Paul
spanning tree enable in global
i tried power inline never
now i use " switchport host "command and i am testing
Hello Paul
i used " switchport host "command
but devices disconnected
Hello Paul
