disparate vlans on a trunk
axfalk
We've configured a head-end layer 3 switch and, downstream from it, an access switch (CatOS). The 2 ints (2/4 & 3/4) on the head-end switch are in an Etherchannel and the 2 corresponding ports on the access switch (2/4 & 3/4) form a trunk. The 2/4 int on the router is patched into 2/4 on the switch and the 3/4 is patched into the 3/4 on the switch.
This was working OK for awhile, but this morning we noticed the int 3/4 on the head-end switch was up/down and not in the channel. Yet, it's partner port 3/4 on the access switch is up/up. We verified the cables to make sure the two ports are patched to each other. The error msg we're seeing on the head-end switch is saying: " Te3/4 is not compatible with Te2/4 and will be suspended (trunk mode of Te3/4 is access, Te2/4 is trunk)"...Both ports on the head-end switch are configured identically. The only anomaly we found was that the vlans on the 2 ports forming the trunk on the access switch are not the same, but the native vlan is the same.  Could that be the culprit here?
Thanks..
_ Greg
Reza Sharifi
Greg,
Both ports need to have the same vlans.  If the uplink ports from the access layer switch are trunked, then the ports in the other switch need to be trunked as well. Both sides of the connections have to be configured the same.
zappo0305
Sounds like layer2 issue, check encapsulation on both side. Sh int gix/x switchport
