What are the conditions for a switch port to declare itself as a trunk port?
Steph1963
I would like to know if a trunk can be establish when two switches are connected back to back with the following configurations:
Sw1 -------- Sw2
Sw1
int fa0/1
  switchport mode dynamic auto
  switchport trunk vlan native vlan 10
Sw2
int fa0/1
  switchport dynamic desirable.
If there is not other VLAN define on the two switches except VLAN 1, does both switches needs an operational VLAN 1 to be in trunking mode.
In fact, I am trying to understand the criteria that a switch is using to declare itself as a trunk.
Does it needs to have a successfull DTP negotiation?
What about the case of switchport mode trunk with no DTP negotiation, does it only need layer 1 to be up to declare itself as a trunk?
Thanks for your help
Stephane
johnlloyd_13
Level 9
Level 9
hi stephane,
yes, a trunk will be formed. see show interface switchport command output under "Operational Mode."
Switch1(config)#int f0/1
Switch1(config-if)#switchport mode dynamic auto
Switch1(config-if)#switchport trunk native vlan 10
Switch1#sh int f0/1 switchport
Switchport: Enabled
Administrative Mode: dynamic auto
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 10 (VLAN0010)
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Appliance trust: none
Switch1#
%CDP-4-NATIVE_VLAN_MISMATCH: Native VLAN mismatch discovered on FastEthernet0/1 (10), with Switch2 FastEthernet0/1 (1).
Switch2(config-if)#switchport mode dynamic desirable
Switch2#sh int f0/1 switchport
Switchport: Enabled
Administrative Mode: dynamic desirable
Trunking Native Mode VLAN: 1 (default)
Voice VLAN: none
Protected: false
see DTP switchport mode interaction matrix below and note this table assumes DTP is enabled on both ends.
                                   Dynamic Auto             Dynamic Desirable   Trunk                 Access
Dynamic Auto             Access                       Trunk                        Trunk                 Access
Dynamic Desirable    Trunk                           Trunk                        Trunk                 Access
Trunk                          Trunk                           Trunk                        Trunk                Not recommended
Access                       Access                        Access            Not recommended    Access
as you saw in the output, this setup resulted to a native VLAN mismatch. trunk ports configured with different native VLANs generates this error in console and causes traffic to be misdirected and could pose a security risk.
Reza Sharifi
Stephane,
You only need to have a trunk port when you carry more then one vlan (not including the native vlan) in a link.
sw1-------sw2
in the above if you only have one vlan (lets assume vlan 20) then you can make the port a switch port
If you are carrying more then one vlan (lets assume 20 and 30) then you need a trunk port.
Native vlan is 1 by default, but can be changed to any other number.  If you change it vlan 1 then that vlan needs to be in both switches.  In this case the native vlan carries untagged traffic only.
Reza
johnlloyd_13
Level 9
Level 9
hi stephane,
Switchport: Enabled
Voice VLAN: none
Protected: false
Switch1#
Switchport: Enabled
Voice VLAN: none
Protected: false
