Distance eigrp 90 90 WS-6500 VSS
jesusresendiz
I have a client that has WS-6500 in VSS with NSF. By deleting the command distance eigrp 90 90, the neighboring devices resynchronized their eigrp adyacency. After this, the metrics appeared as infinity, causing an instability in the network. Why this happen?
Does i need to execute a clear ip eigrp?
WS-6500-VSS#show ip eigrp topology 10.1.1.0/24
EIGRP-IPv4 Topology Entry for AS(10)/ID(10.1.2.1) for 10.1.1.0/24
  State is Active, Query origin flag is 1, 1 Successor(s), FD is 3328512
Waiting for 1 replies
  Descriptor Blocks:
  10.1.4.254 (GigabitEthernet1/1/1), from 10.1.4.254, Send flag is 0x0
      Composite metric is (Infinity/Infinity), route is Internal
      Vector metric:
        Minimum bandwidth is 1000000 Kbit
        Total delay is 281438776 microseconds
        Reliability is 255/255
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 1
Reza Sharifi
Have a look at this document for an explanation:
https://www.packetmischief.ca/2015/04/07/eigrp-fd-is-infinity/
