05-27-2016 02:04 AM - edited 03-08-2019 05:58 AM
I got three router R1, R3,and R2, R2 is hub, R1 can ping R2 through f0/0, now R3 can't ping R2. but in R3 it can show nhs and nhrp.
since f0/0 in R2 is used for R1 connection, how should I do? I can't draw a line between R3 (spoke)and R2(hub)pls see attached GNS3 screen
if I don't draw a line between R2 and R3, in R3 I can't ping R2 10.1.0.2
R3:
interface Loopback0
ip address 150.1.0.3 255.255.255.0
interface Tunnel0
ip address 10.1.0.3 255.255.255.0
ip nhrp authentication cisco123
ip nhrp map multicast 169.254.100.2
ip nhrp map 10.1.0.2 169.254.100.2
ip nhrp network-id 99
ip nhrp nhs 10.1.0.2
tunnel source FastEthernet0/0
tunnel destination 169.254.100.2
interface FastEthernet0/0
ip address 169.254.100.3 255.255.255.0
duplex auto
speed auto
R2:
interface Loopback0
ip address 150.1.0.2 255.255.255.0
interface Tunnel0
ip address 10.1.0.2 255.255.255.0
no ip redirects
ip nhrp map multicast dynamic
tunnel mode gre multipoint
ip address 169.254.100.2 255.255.255.0
duplex auto
speed auto
05-27-2016 01:46 PM
You can't jam two cables into one interface in real life, and you won't be able to do that in GNS3 either.
You need to emulate a WAN network with full connectivity between all nodes, because that's the kind of WAN connectivity (like the Internet) you would use for a DMVPN.
Instead of the routers connecting to each other directly, they should all connect to either a:
L3 switch
L2 switch
Tim
05-29-2016 11:14 PM
No, we use cloud instead, but my machine is forbidden to run VMWare, I create three null port R1. R2 and R3 in the cloud to connect to R1, R2, R3 's f0/0 interface, but not working, is any expert in GNS3 can give some advice how to configure cloud for DMVPN, now in R3, I can't ping to R(hub)
