DNS ROUTING FQDN
phipse_508122
Hi Everyone,
I have a FQDN object on our Firewall, the IP address of this changes daily so the firewall has a rule to permit access to it on a specified port number.
Example:
access-list inside_access_in line 284 extended permit tcp host 192.168.0.25 host 191.235.193.75 (database.windows.net) eq 1433 (hitcnt=0) 0xeef0bf01
This is working great, however I can not route traffic to the firewall from our CORE 6500 series switches if I don't know the IP address of the object.  I have a server that needs to access this FQDN object.
How do I route traffic from our CORE to the firewall?
CORE Cisco 6509's (s2t54-ipservicesk9-mz.SPA.150-1.SY2.bin)
Firewall Cisco ASA 5540 v9.1(5)21
2 Accepted Solutions
Richard Burts
If the IP address changes daily then it seems that using Policy Based Routing to forward traffic for TCP 1433 might be the solution for you.
Rick
Rick
It might look something like this
access-list 199 permit tcp any any eq 1433
route-map SQLtraffic permit 10
match ip address 199
set ip next-hop <fw_addr>
interface vlan 20
ip policy SQLtraffic
Rick
Rick
7 Replies 7
Richard Burts
Rick
Rick
Thanks Rick,
Can you give an example of this?
interface vlan 20
Rick
Rick
I thought so.
Thanks again Rick
So Rick... what do you think if the requirements are that only traffic destined to that specific FQDN (say toto.database.windows.net which changes with time) should be routed to a specific interface and not every tcp flow destined to 1433...?
I think that is quite a challenge. I would try writing a script with EEM which you could schedule every x interval. In the script you could check on the FQDN and if the address has changed then you could perform an edit on the access list used for PBR.
Rick
Rick
vinayjaiswal
Level 3
Level 3
Hi Richard,
is there any FQDN PBR sript link so we can do it for cisco 9500 switches?
