Do Catalyst switches forward Precision Time Protocol (PTP) packets?
kyle dickinson
Community Member
I understand that the Catalsyt Switch range do not provide PTP Boundary Clocks. However can they still forward PTP packets from a PTP server to a PTP client connected to a port on Catalyst Switch, in particular the 4900M and 3750-X series. I do understand that any switching delay would affect the accuracy of the PTP clock.
Jon Marshall
Switches forward frames based on mac address.
They do not care what the payload of the packet is.
So yes they can.
Jon
So if I have a L2 network consisting of severall access switches connected via trunks to a distribution, with PTP clients in differing VLAN's, as long as each VLAN has a connection to the PTP source then the client will receive the PTP timestamp allthough subject to switching delays?
As long as there is routing setup between the vlans then yes the clients should receive the packets subject to any latency within the switches as you say.
Jon
Thanks Jon for the confirmation.
