Inter vlan routing with ipv6
Morning,
Basically I'm trying to configure inter vlan routing using IPv6 addressing. I've been searching all over the net for any guides as to how configure inter vlan routing using IPv6 addressing yet I can't find any anywhere.
Is there any differences between the configuration used for IPv4 and IPv6 (obviously bar the addressing structure)?
Any help would be grately appreciated!
Cheers,
Michael
cciepending
I tested with packet tracer it same ipv4 configuration
R1(2811)connected to switch 2960 with trunk port and 2 router as client connected to switch 2960 (
because pc in packet tracer ipv6 not support i use router as client )
Create 2 sub interface in router
R1
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.2
encapsulation dot1Q 2
no ip address
ipv6 address 2:2:2:2::1/64
interface FastEthernet0/0.3
encapsulation dot1Q 3
no ip address
ipv6 address 3:3:3:3::1/64
Create vlan 2 and 3 in switch
interface FastEthernet0/2
switchport access vlan 2
switchport mode access
interface FastEthernet0/3
switchport access vlan 3
then assign ipv6 to R2 and R3
R2
no ip address
duplex auto
speed auto
ipv6 address 2:2:2:2::2/64
R3
no ip address
duplex auto
speed auto
ipv6 address 3:3:3:3::3/64
For R2 and R3 assign static route to R1 (of course you can assign default route)
R2
ipv6 route 3:3:3:3::/64 FastEthernet0/0 2:2:2:2::1
R3
ipv6 route 2:2:2:2::/64 FastEthernet0/0 3:3:3:3::1
R3#ping 2:2:2:2::2
Sending 5, 100-byte ICMP Echos to 2:2:2:2::2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 14/15/18 ms
R1
Show ipv6 route
C   2:2:2:2::/64 [0/0]
     via ::, FastEthernet0/0.2
L   2:2:2:2::1/128 [0/0]
C   3:3:3:3::/64 [0/0]
     via ::, FastEthernet0/0.3
L   3:3:3:3::1/128 [0/0]
L   FF00::/8 [0/0]
     via ::, Null0
Please rate the helpful posts
OK you created the vlans with IPv6 and/or IPv4 addresses?  You did not include that.
