Do not operate equal routing
Jung woo Son
we set the following config and version.
interface FastEthernet0/1
 no switchport
 bandwidth 5000
 ip address 10.0.88.98 255.255.255.252
interface FastEthernet0/2
 no switchport
 bandwidth 5000
 ip address 10.0.65.54 255.255.255.252
 speed 100
 duplex full
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 10.0.88.97
ip route 0.0.0.0 0.0.0.0 FastEthernet0/2 10.0.65.53
This is WS-C3550-24-PWR and the Version is 12.2(44)SE6.
show ip route
S*   0.0.0.0/0 [1/0] via 10.0.88.97, FastEthernet0/1
               [1/0] via 10.0.65.53, FastEthernet0/2
but the traffic do not flow on fa0/1(only Rx is flowing).
After upgrading IOS, this issue comes up.
I don't know what problem is.
C3550#sh int fa0/1
FastEthernet0/1 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 000f.23d2.2d80 (bia 000f.23d2.2d80)
  Internet address is 10.0.88.98/30
  MTU 1500 bytes, BW 5000 Kbit, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 248/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 07:28:40
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 5373000 bits/sec, 648 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     20257639 packets input, 304311820 bytes, 0 no buffer
     Received 491 broadcasts (0 IP multicasts)
     0 watchdog, 491 multicast, 0 pause input
     38101 packets output, 3506824 bytes, 0 underruns
C3550#sh int fa0/2
FastEthernet0/2 is up, line protocol is up (connected)
   Internet address is 10.0.65.54/30
     reliability 255/255, txload 57/255, rxload 122/255
  Last input 00:00:00, output 00:00:02, output hang never
  Last clearing of "show interface" counters 07:28:43
  5 minute input rate 2395000 bits/sec, 399 packets/sec
  5 minute output rate 1124000 bits/sec, 840 packets/sec
     16451106 packets input, 4206692166 bytes, 0 no buffer
     Received 493 broadcasts (0 IP multicasts)
     0 watchdog, 493 multicast, 0 pause input
     33644613 packets output, 2228991756 bytes, 0 underruns
mmoulson1
Level 4
Level 4
"Per-destination load balancing means the router distributes the packets based on the destination address. Given two paths to the same network, all packets for destination1 on that network go over the first path, all packets for destination2 on that network go over the second path, and so on. This preserves packet order, with potential unequal usage of the links. If one host receives the majority of the traffic all packets use one link, which leaves bandwidth on other links unused."
Have a look here:
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/5212-46.html
