does cisco 2901 support T3/E3 network module?
mirinda20
Community Member
         Hiii
          Does router 2901 Support T3/E3 Module ?
   thank you
Richard Burts
I have looked and do not find any T3/E3 module that is supported on 2901 router.
Rick
Rick
Marvin Rhoads
The product data sheet for the NM-1T3/E3 indicates that only the 2951 is supported from among the 2900 series models.
Marvin
That is correct . But also have a look at SM-X-1T3/E3 which is supported on 2911 and higher according to this link
http://www.cisco.com/en/US/prod/collateral/modules/ps2706/qa_c67-728547_ps12522_Products_Q_and_A_Item.html
Rick
Rick
Hi Rick - Good find.
I hadn't seen that one before - looks like it was just released this summer from the IOS required for it.
