11-07-2018 12:18 PM - edited 03-08-2019 04:34 PM
I have a ws-c3650-48ps-L
the front panel shows 48 POE+ 2X10G with ports TE3 and TE4 labeled as well.
However the datasheet, and in the config, however, they are listed as gigabitethernet 1/1/3 and 1/1/4
Does this switch actually have two 10g interfaces? If so how do I configure them for 10gig
11-07-2018 12:41 PM
That switch has only 4 1Gig ports and no 10Gig.
WS-C3650-48PS-L
from the data sheet:
Standalone with Optional Stacking 48 10/100/1000 Ethernet PoE+ and 4x1G Uplink ports, with 640WAC power supply, 1 RU, LAN Base feature set
link
11-07-2018 12:42 PM
Dear, 3650-48PS has only Gigabit port. Probably the chassis is the same for all 3650 model.
WS-C3650-48PS-L |
Standalone with Optional Stacking 48 10/100/1000 Ethernet PoE+ and 4x1G Uplink ports, with 640WAC power supply, 1 RU, LAN Base feature set |
In case that you need 10Gb SFP+ you should buy a 3650-48PD-L
WS-C3650-48PD-L |
Standalone with Optional Stacking 48 10/100/1000 Ethernet PoE+ and 2x10G Uplink ports, with 640WAC power supply, 1 RU, LAN Base feature set |
11-07-2018 12:43 PM
11-07-2018 12:43 PM
WS-C3650-48PS-L - Standalone with Optional Stacking 48 10/100/1000 Ethernet PoE+ and 4x1G Uplink ports, with 640WAC power supply, 1 RU, LAN Base feature set
WS-C3650-48PD-L - Standalone with Optional Stacking 48 10/100/1000 Ethernet PoE+ and 2x10G Uplink ports, with 640WAC power supply, 1 RU, LAN Base feature set
11-07-2018 12:51 PM - edited 11-07-2018 12:53 PM
Can you post show inventory to check what kind of SFP you have installed in the modules.
as per specification 4 X SFP.
11-07-2018 03:17 PM
