Does Nexus 3064 support Priority Flow Control
addylplam
Frequent Visitor
Frequent Visitor
Hi there, I have a Nexus 3064 running NX-OS 6.0(2)U1(2) and would like to enable Priority Flow Control on a few 10G ports.  I cannot find any option to configure PFC, so I am wondering it is actually supported on the 3064.  Thanks.
Addy
edwinlgreene
Frequent Visitor
Frequent Visitor
Addy,
Were you able to get an answer for PFC on the 3064?
Hi Addy, edwinlgreene
Did either of you find anything here?
MJ
MJ, I wasn't able to find resolution on the support forums.  I basically dropped it since I moved on to other project work.
Ok, Thanks for the response. Will post here if I find anything.
