Does 'sh int' include multicast packet ?
henrybb
Level 6
Level 6
Loop occured in my network.After I sh int , I have some question.
Almost all input packet is broadcast,so where is multicast ? Does the number of broadcast include multicast ?
thanks!
switch#sh int g2/24
GigabitEthernet2/24 is administratively down, line protocol is down (disabled)
Hardware is C6k 1000Mb 802.3, address is 0012.0165.220f (bia 0012.0165.220f)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 0/255, rxload 0/255
Full-duplex, 1000Mb/s, media type is SX
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 2d06h, output 2d06h, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
4826063024 packets input, 315908754162 bytes, 0 no buffer
Received 4822155236 broadcasts, 0 runts, 0 giants, 0 throttles
4672521890 packets output, 306231117497 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 lost carrier, 0 no carrier
I don't know which model of Cisco Switch you have,
Here is the output from one of my C2960 which do seems to have this counter under the show interface command.
Switch#sh int fa 0/1
FastEthernet0/1 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 001a.e2d2.fd81 (bia 001a.e2d2.fd81)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 2d18h, output hang never
23913299 packets input, 2949977365 bytes, 0 no buffer
Received 30877 broadcasts (0 multicast)
3 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 26 multicast, 0 pause input
28119602 packets output, 186334128 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Shaheen
My switch is 6509.It doesn't have.
6509A>sh ver
IOS (tm) s72033_rp Software (s72033_rp-PSV-M), Version 12.2(17d)SXB11, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 15-Nov-05 16:03 by pwade
Image text-base: 0x40020FBC, data-base: 0x41C98000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PSV-M), Version 12.2(17d)SXB11, RELEASE SOFTWARE (fc1)
400-6509-A uptime is 5 weeks, 2 days, 5 hours, 1 minute
Time since 400-6509-A switched to active is 5 weeks, 2 days, 5 hours, 0 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by power-on)
System restarted at 04:03:53 bj Sun Nov 11 2007
System image file is "sup-bootflash:s72033-psv-mz.122-17d.SXB11.bin"
cisco WS-C6509 (R7000) processor (revision 2.0) with 458752K/65536K bytes of memory.
Processor board ID SMG0847A019
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
29 Virtual Ethernet/IEEE 802.3 interface(s)
122 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
