Does TDR cable-diagnostic work when end device is off?
bselcuk
We have about 120 cables connected at the end with fast-ethernet PoE devices. Since we have PoE troubles, many devices are not online / getting power. However, we want to check if there is any cable issue.
Does "test cable-diagnostic tdr" has a useful result when the end is offline / not connected at all ?
The device works on Fast-Ethernet, as I've read in TDR guide that Pair C and D is only tested when its recognized as Gigabit, is this true? When PoE is working, Pair C should give a result, shouldn't it?
When the cable is correct and PoE is working, the output should be like this or is this wrong?
Pair A Normal
Pair B Normal
Pair C Short
Pair D Short
Switches are C9200L-24P-4X
W-ALI
this output fro C3750X
Leo Laohoo
I want to know the exact firmware version the switch is running on and the uptime (yes, it matters).
I also want to the complete output to the command "sh cable tdr interface <PORT>".
Unless someone is testing the wrong port or someone is using an injector.
If the port is getting power AND the TDR result is showing only Pairs A and B are "Normal", then verify that with the command "sh power inline".
debug ilpower powerman
share this output let see what we will get
