WS-C3750V2-48PS-S switch some ports not releasing IP address
amit.gaur
We have stack of 4 switches WS-C3750V2-48PS-S and  some ports in 1 switch misbehaving .
User is connecting laptop on port and in arp table it is showing IP assigned under the assign vlan for port but that IP is not reachable . and when I am checking on user laptop IPconfig/all it is showing apipa IP.
6 Replies 6
Reza Sharifi
Is the DHCP scope configured correctly? Does the switch assign IPs or a server? Can you post the output of "sh run"?
amit.gaur
Yes , DHCP scope is configured correctly some interface under same vlan having no issues with same configuration .
We have IP helper address configured for vlan. thanks to confirm you need show run for impacted interfaces or whole switch .
amit.gaur
can anyone please help to solve the issue
what is issue?
the DHCP or forward traffic ?
Jitendra Kumar
you should have to try below commands on the laptop.
ipconfig /release
ipconfig /renew
have you tried that port shut/no shut.
Jitendra
