Dot1x and speed/duplex issue
kerunitah29
I am implementing dot1x (IBNS2) on mainly C9200 and seems to work mostly great but we have some devices that just have to have ”speed auto 10” on the port to work properly (cant do anything about it). My first idea was to apply via ISE an special template with ”speed auto 10” but I cant define speed-command in the inteface template etc, any tips how to solve it so these devices can use any port and dont need dedicated ports.
We also have a simular issue where some locations have old copper cables for clients but APs have CAT6+ so I could configure client ports as auto 100 10 but then if a AP use that port in the future AP will get max 100mbps.. my goal was to have the same port configurtion on all access ports.
Try below
1- config all port with 10
2- use EEM event CDP check the neighbor if it AP then action change the Speed to be 100 or more
MHM
balaji.bandi
if this is only one switch, when you Migrating to 9200 you may need to plan to move the ports or patch the ports with respected config pre-applied.
AP wont move in everyday base, same also with PC right ?
BB
