08-14-2018 07:31 AM - edited 03-08-2019 03:54 PM
I just swapped a 3650 out, put the original config on it and the dot1x config does not want to work and neither did the RADIUS. The switch I replaced it with must have a newer IOS on it, which needs newer commands. We have sorted the RADIUS with a different set of commands, but the dot1x just refuses to work. The newer IOS that it is running is:
CAT3K_CAA-UNIVERSALK9 16.3.5
dot1x system-auth-control
aaa group server radius CONF-Dot1x
server 10.***.**.101
server 10.***.**.102
aaa authentication dot1x default group CONF-Dot1x
aaa authorization network default group CONF-Dot1x
aaa accounting dot1x default start-stop group CONF-Dot1x
interface GigabitEthernet1/0/1
switchport access vlan 958
switchport mode access
switchport voice vlan 959
dot1x pae authenticator
spanning-tree portfast
spanning-tree bpduguard enable
We get the following errors:
Aug 14 14:24:32.852: %DOT1X-5-FAIL:Switch 1 R0/0: smd: Authentication failed for client (001E.0B68.3CA1) on Interface Gi1/0/1 AuditSessionID 0ADEF08200000B4437A1E4F1
Aug 14 14:24:32.858: %SESSION_MGR-5-FAIL:Switch 1 R0/0: smd: Authorization failed or unapplied for client (001E.0B68.3CA1) on Interface GigabitEthernet1/0/1 AuditSessionID 0ADEF08200000B4437A1E4F1
Anybody have any ideas how we can fix this or what additional config is needed?
Solved! Go to Solution.
08-14-2018 09:15 AM
Yeah, the Denali code has changed things up. For us it messed up IPDT. Follow the config guide and you should be able to get it working.
08-14-2018 09:15 AM
