Double Sided VPC between Fabric path enable and non Fabric switch
Hi Experts
I am trying to make the double sided vpc as below where N77 pair is fabric path enabled and peer-link is also fabric path enabled. but below 5K switches are not fabric patch enabled and peer-link is also normal trunk link. is it possible to establish the double sided VPC between N77 and 5K pairs and it will work like normal?
Gurbinder
0 Replies 0
