Doubts about 802.1x authentication using Control Policy (C3PL)
edylamanta
cuando mi cliente no soporta 802.1x, se supone que el puerto del switch debe permanecer en estado no autorizado. Pero no logro que esto funcione.
¿Sabe alguien como se logra esto?
This is may configuration:
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
radius server ServidorCPPM
address ipv4 192.168.1.1 auth-port 1812 acct-port 1813
key peppearste
dot1x system-auth-control
class-map type control subscriber match-any AAA-DOWN
match result-type aaa-timeout
exit
class-map type control subscriber match-all DOT1X-FAILED
match method dot1x
match result-type method dot1x authoritative
exit
class-map type control subscriber match-all DOT1X_NO_RESP
match method dot1x
match result-type method dot1x agent-not-found
exit
policy-map type control subscriber DOT1X-DEFAULT
event session-started match-all
  10 class always do-all
   10 authenticate using dot1x priority 10
event violation match-all
   10 restrict
event agent-found match-all
event authentication-failure match-all
10 class AAA-DOWN do-all
   10 terminate dot1x
  20 class DOT1X_NO_RESP do-all
   10 terminate dot1x
   20 unauthorize
30 class DOT1X-FAILED do-all
   10 terminate dot1x
  40 class always do-until-failure
   10 terminate dot1x
   20 authentication-restart 60
interface GigabitEthernet0/1
switchport mode access
service-policy type control subscriber DOT1X-DEFAULT
authentication periodic
authentication timer reauthenticate server
mab
access-session host-mode multi-auth
dot1x timeout tx-period 10
access-session port-control auto
dot1x pae authenticator
interface Vlan109
ip address 192.168.1.254 255.255.255.0
Thank you
jalemanp
Se que ha pasado unos meses ya, pero logró resolver el problem?
Si no, cual es el estado del puerto con el comando "show access-session interface (interface_id) details_
Saludos,
