Downloading Issue - Soho router 91
Hello Guys
I have my provider's modem connected to ethernet 1 port of my soho(91) router and ethernet 0
port is connected to a 2960 switch. On the switch i have my clients connected.
Switch has it's default factory configuration (no extra vlans have been created)
I have the following weird issue
Whenever i try to download a file from the internet using windows 7 client it starts downloading
and stops after a period of time which is not specific (sometimes after 30 second, sometimes after 45)
When i try to download the same file using windows xp the file it's downloading successfully
I;ve disabled the firewall on the client in order to see if that was the problem with no luck.
As i mentioned above no configuration has been made on the switch.
I've connected also the win 7 client on the switch port that win xp client was connected and i got the same issue.
I've test several windows 7 clients and all have the same issue.
The only thing that left unchecked is to upgrade the ios of my Soho router since the ios is 12.2(8)YN which was released back in 2003 and windows 7 OS was released in 2007 and maybe Microsoft has changed the way of downloading a file and that changed was unknown to that cisco ios release.
Please see below the configuration of my router maybe i have to remove or add some extra lines
Current configuration : 3447 bytes
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Test
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 x
username Administrator x
aaa new-model
aaa authentication login default local
aaa authentication login CON none
aaa authentication ppp default local
aaa session-id common
ip subnet-zero
ip name-server 194.10.115.25
ip dhcp excluded-address 10.0.0.254
ip dhcp pool CLIENT
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.254
   domain-name mydomain
   dns-server 10.0.0.1
   lease 0 2
ip inspect name myfw cuseeme timeout 3600
ip inspect name myfw ftp timeout 3600
ip inspect name myfw rcmd timeout 3600
ip inspect name myfw realaudio timeout 3600
ip inspect name myfw smtp timeout 3600
ip inspect name myfw tftp timeout 30
ip inspect name myfw udp timeout 15
ip inspect name myfw tcp timeout 3600
ip inspect name myfw h323 timeout 3600
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
  protocol pptp
  virtual-template 1
no crypto isakmp enable
interface Ethernet0
  ip address 10.0.0.254 255.255.255.0 secondary
ip address 10.10.10.1 255.255.255.0
ip nat inside
no ip mroute-cache
no cdp enable
hold-queue 32 in
interface Ethernet1
ip address 194.10.115.18 255.255.255.252
ip access-group 111 in
ip nat outside
ip inspect myfw out
no ip mroute-cache
duplex auto
no cdp enable
interface Virtual-Template1
ip unnumbered Ethernet0
peer default ip address pool pptp
ppp authentication chap
ip local pool pptp 10.0.0.245 10.0.0.250
ip classless
ip route 0.0.0.0 0.0.0.0 [ISP'S IP]
ip http server
no ip http secure-server
ip nat inside source list 102 interface Ethernet1 overload
ip nat inside source static tcp 10.0.0.1 80 interface Ethernet1 80
access-list 23 permit 10.0.0.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 102 permit ip 10.0.0.0 0.0.0.255 any
access-list 111 permit icmp any any administratively-prohibited
access-list 111 permit icmp any any echo
access-list 111 permit icmp any any echo-reply
access-list 111 permit icmp any any packet-too-big
access-list 111 permit icmp any any time-exceeded
access-list 111 permit icmp any any traceroute
access-list 111 permit icmp any any unreachable
access-list 111 permit udp any eq bootps any eq bootpc
access-list 111 permit udp any eq bootps any eq bootps
access-list 111 permit udp any eq domain any
access-list 111 permit esp any any
access-list 111 permit udp any any eq isakmp
access-list 111 permit udp any any eq 10000
access-list 111 permit tcp any any eq www
access-list 111 permit tcp any any eq 1723
access-list 111 permit tcp any any eq 139
access-list 111 permit udp any any eq netbios-ns
access-list 111 permit udp any any eq netbios-dgm
access-list 111 permit gre any any
access-list 111 deny   ip any any
no cdp run
control-plane
line con 0
exec-timeout 120 0
no modem enable
transport preferred all
transport output all
stopbits 1
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 120 0
length 0
transport input all
scheduler max-task-time 5000
end
'no ip inspect' should disable the firewall. Keep in mind that only traffic permitted by ACL 111 will be permitted through after you remove the inspection. Using ip inspect creates stateful sessions so that traffic doesn't have to be permitted by the external ACL.
After removing, you can do a sh ip inspect session to make sure it was removed correctly. If not, you can use the clear ip inspect command to remove it.
rfalconer.sffcu
Level 3
Level 3
Microsoft completely re-did the TCP/IP stack for Windows Vista and Server 2008. So networking in Windows 7, which uses the same stack, is very different from Windows XP. This is typically a very good thing due to improved performance.
A couple of questions on your configuration:
Is that default route correct? It's not on the same network as your E1 interface.
What is the IP address of your Windows 7 machine?
Have you temporarily disabled the firewall on the router to test without that?
Yes it's the correct route i've changed it in order not to expose my network.
If it was a routing problem i wouldn't be able to reach the internet at all since if the router needs to route a packet to a network that is not in its routing table it will try to send it via the default route , am i right?
Windows 7 clients receive addresses from the range of the DCHP pool called "CLIENT" the same happens with Windows XP clients
example   ip; 10.0.0.2/24
               gw: 10.0.0.254
               dns 10.0.0.1 (which is a windows server 2003 small business)
I forgot to mentioned that this is a windows domain enviroment. I also removed the client from the domain and tried the same ip addresing scheme static with dns 8.8.8.8 with no luck.
How do i disable the firewall on the router? I tried to remove ip inspection from ethernet1 but when i did it i wasn't able to reach the internet. so i reenabled it.
