Driver for USB Console for Catalyst 2960-X 24 GigE - for Windows 8 Pro
anantha74in
Hi There,
I need Driver for USB Console for Catalyst 2960-X 24 GigE - for Windows 8 Pro
your help will be highly appreciated
BR
Anantha
Not sure why it's not listed under the 2960x but it's the same driver here: https://software.cisco.com/download/release.html?mdfid=282867574&softwareid=282855122&release=3.1
I'm using this on Windows 10 and Windows 7 hosts with minimal issues.
Ganesh Hariharan
Hi There,
BR
Anantha
Hi Acanthi,
Check out the below link for downloading drivers for PC , Hope it Helps..
https://www.petri.com/cisco-usb-console-connection-setup
-GI
Rate if it Helps.
HI
I have downloaded using the link but its driver for Windows Vista / XP. I need for windows 8 Pro - 64 Bit
BR
Anantha
