dscp marking in Cisco 2960S -- 12.2 (55)SE3
kindly check the below config, which i did on cisco 2960S switch at user ingress interface. but the marking is not showing in show policy-map interface gig 1/0/10 interface and ACL is not showing any match.
I also had a config reference from 2960S cisco guide.
Kindly confirm am I missing any parameter from config......
access-list 103 permit tcp any any eq 80
access-list 104 permit tcp any any eq 23
access-list 105 permit icmp host 172.24.68.4 any
class-map IN_HTTP
match access-group 103
class-map IN_TELNET
match access-group 104
class-map IN_ICMP
match access-group 105
policy-map MARKING
class IN_HTTP
set dscp af32
class IN_TELNET
set dscp af31
class IN_ICMP
set dscp af22
int gig 1/0/24
service-policy input MARKING
exit
cadet alain
the command you used is not supported on this platform, you should use this one instead:
show  mls qos interface gigabitEthernet 1/0/24 statistics
Regards.
Alain
