Dual ISP and more LAN.
tothz
Hi Everybody
I have a task which I can not solve it. :-(  There is a small company with two separated Internet service provider. Inside a company there are two separated LAN. One of these LAN should use first ISP.
The other LAN has more separated part. One of these part should use first ISP, and the other part should use second ISP. It can be accomplished by a layer 3 Cisco switch, as you can see in the picture ?
Zoltan
Deepak Kumar
What is the model number of your core switch and IOS version?
You can archive the same with PBR routing.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
The current device 3560v2 with ipbase IOS, but I can change the IOS if required.
The firs idea was the PBR, but how can I implement ?  I have created two vlan and vlan interfaces for LAN A and LAN B. What is next ?
Zoltan
You can visit below link and follow the steps:
http://www.ciscozine.com/pbr-route-a-packet-based-on-source-ip-address/
https://networklessons.com/cisco/ccie-routing-switching/how-to-configure-policy-based-routing/
If you will face any issue with configuration, Please share your switch configuration with me. I will make for you.
Deepak Kumar
Deepak Kumar,
