Duplex Error in my network
Friends,
Recentdays I Can see this duplex error in my switch and router.
"Duplex mismatch discovered on Gig0/1 ( Not Halfduplex) with Switch1 Gi1/0/1(Half duplex)"
but I checked in both ends. Both ends are set it as "Full Duplex". if i set as "Half duplex" is that will lead of down time. Pls suggest to aviod the mismatch.
Tamil..
Jerry Ye
If both side has the same setting, then you should check your cable.
jerry
