Duplicate IP
dmah2011001
Community Member
I have a machine that was configured with a static IP and a static NAT to an external address.  I've taken it offline to troubleshoot what I thought was an O/S problem.  Turns out there was a duplicate IP on the network.  I determined that it was the router that duplicated the IP (10.0.1.20).  I thought deleting the static NAT entry would solve the issue, but it has not.  I verified the the IP is no longer listed in the NAT table but the router is still responding to the IP.
>show ip arp | include c89c
Internet  10.0.0.1                -   c89c.1dcf.3400  ARPA   GigabitEthernet0/0
Internet  10.0.1.20               -   c89c.1dcf.3400  ARPA   GigabitEthernet0/0
>>show ip nat translations | include 10.0.1.20
no entries
I'm not sure what I need to clear to resolve this.
Thanks.
7 Replies 7
Jon Marshall
You are going to need to remove the actual NAT statement from the router.
Edit - it actually sounds like that is what you did. Apologies it's been a long day
Jon
manju.cisco
Level 7
Level 7
Hii
Looks like the ip 10.0.1.20 is in the same device interface....., may be its configured as secondary address??? not sure...just my guess...... can u try show run gig0/0 and see if it has any........
Thanks.
#show run | section (GigabitEthernet0/0)
interface GigabitEthernet0/0
description xxxxxxxxxxxxxxxxx
ip address 10.0.0.1 255.255.252.0
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
can you try disabling nat on the interface and clear ip arp entry.
Regards.
Alain.
I was hoping to avoid doing anything distruptive like disabling nat entirely or restarting the router.
I did try clearing the single arp entry, but that doesn't seem to have any effect.
#show ip arp | include 10.0.1.20
#clear ip arp 10.0.1.20
can you post the config of the router and if possible the lan switch this interface connects to.
res
Paul
Kind Regards
Paul
version 15.0
ip name-server XXXXXX
ip inspect tcp window-scale-enforcement loose
ip inspect tcp reassembly queue length 512
ip inspect tcp reassembly timeout 10
ip inspect name block appfw block
ip inspect name block http timeout 1800
ip inspect name block udp timeout 1800
ip inspect name block tcp timeout 1800
ip inspect name block icmp timeout 1800
ip inspect name block ftp timeout 1800
ip inspect name sdm_ins_in_100 appfw block
ip inspect name sdm_ins_in_100 http urlfilter timeout 1800
ip inspect name sdm_ins_in_100 udp timeout 1800
ip inspect name sdm_ins_in_100 tcp timeout 1800
ip inspect name sdm_ins_in_100 icmp timeout 1800
ip inspect name sdm_ins_in_100 ftp timeout 1800
appfw policy-name block
  application http
    port-misuse p2p action reset alarm
class-map match-any CCP-Transactional-1
match  dscp af21
match  dscp af22
match  dscp af23
class-map match-any CCP-Voice-1
match  dscp ef
class-map match-any sdm_p2p_kazaa
match protocol fasttrack
match protocol kazaa2
class-map match-any CCP-Routing-1
match  dscp cs6
class-map match-any CCP-Signaling-1
match  dscp cs3
match  dscp af31
class-map match-any sdm_p2p_edonkey
match protocol edonkey
class-map match-any sdm_p2p_gnutella
match protocol gnutella
class-map match-any CCP-Management-1
match  dscp cs2
class-map match-any sdm_p2p_bittorrent
match protocol bittorrent
policy-map CCP-QoS-Policy-1
class CCP-Voice-1
    priority percent 33
class CCP-Signaling-1
    bandwidth percent 5
class CCP-Routing-1
    bandwidth percent 5
class CCP-Management-1
    bandwidth percent 5
class CCP-Transactional-1
    bandwidth percent 5
class class-default
    fair-queue
     random-detect
policy-map CCP-QoS-Policy-2
class sdm_p2p_edonkey
   drop
class sdm_p2p_gnutella
   drop
class sdm_p2p_kazaa
   drop
class sdm_p2p_bittorrent
   drop
class class-default
    shape average 6144000
  service-policy CCP-QoS-Policy-1
policy-map sdmappfwp2p_block
   drop
   drop
class sdm_p2p_kazaa
   drop
   drop
policy-map sdm-qos-test-123
class class-default
description **   LAN  **$ETH-LAN$
ip flow ingress
ip flow egress
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1
description $ETH-WAN$
ip address XXX.XXX.XXX.41 255.255.255.240
ip access-group 110 in
ip flow ingress
ip flow egress
ip nat outside
ip inspect sdm_ins_in_100 in
ip inspect block out
duplex auto
speed auto
crypto map VPN
service-policy input sdmappfwp2p_block
service-policy output CCP-QoS-Policy-2
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
ip local pool VPNCLIENT 172.16.16.1 172.16.16.50
ip forward-protocol nd
ip http server
ip http secure-server
ip flow-top-talkers
top 10
sort-by bytes
cache-timeout 600000
ip nat pool NAT XXX.XXX.XXX.42 XXX.XXX.XXX.42 netmask 255.255.255.240
ip nat inside source route-map NAT pool NAT overload
ip nat inside source static tcp 10.0.0.100 25 XXX.XXX.XXX.42 25 route-map SDM_RMAP_1 extendable
ip nat inside source static tcp 10.0.0.170 80 XXX.XXX.XXX.42 80 route-map SDM_RMAP_11 extendable
ip nat inside source static tcp 10.0.0.100 110 XXX.XXX.XXX.42 110 route-map SDM_RMAP_4 extendable
ip nat inside source static tcp 10.0.0.170 443 XXX.XXX.XXX.42 443 route-map SDM_RMAP_6 extendable
ip nat inside source static tcp 10.0.0.122 3389 XXX.XXX.XXX.42 3389 route-map SDM_RMAP_3 extendable
ip nat inside source static tcp 10.0.0.170 25 XXX.XXX.XXX.43 25 route-map SDM_RMAP_5 extendable
ip nat inside source static tcp 10.0.0.170 110 XXX.XXX.XXX.43 110 route-map SDM_RMAP_7 extendable
ip nat inside source static tcp 10.0.1.30 80 XXX.XXX.XXX.45 80 route-map SDM_RMAP_10 extendable
ip nat inside source static tcp 10.0.1.30 3389 XXX.XXX.XXX.45 3389 route-map SDM_RMAP_9 extendable
ip route 0.0.0.0 0.0.0.0 207.228.94.33
logging trap debugging
logging 10.0.2.180
access-list 100 remark CCP_ACL Category=2
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.50
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.49
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.48
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.47
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.46
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.45
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.44
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.43
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.42
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.41
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.40
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.39
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.38
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.37
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.36
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.35
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.34
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.33
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.32
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.31
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.30
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.29
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.28
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.27
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.26
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.25
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.24
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.23
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.22
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.21
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.20
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.19
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.18
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.17
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.16
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.15
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.14
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.13
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.12
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.11
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.10
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.9
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.8
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.7
access-list 100 deny   ip host 10.0.0.100 host 172.16.16.6
access-list 100 permit tcp host 10.0.0.100 eq smtp any
access-list 101 remark CCP_ACL Category=18
access-list 101 deny   tcp host 10.0.1.20 eq 33445 any
access-list 101 deny   tcp host 10.0.0.170 eq www any
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.1
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.2
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.3
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.4
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.5
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.6
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.7
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.8
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.9
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.10
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.11
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.12
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.13
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.14
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.15
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.16
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.17
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.18
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.19
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.20
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.21
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.22
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.23
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.24
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.25
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.26
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.27
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.28
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.29
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.30
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.31
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.32
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.33
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.34
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.35
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.36
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.37
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.38
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.39
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.40
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.41
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.42
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.43
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.44
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.45
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.46
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.47
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.48
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.49
access-list 101 deny   ip 10.0.0.0 0.0.3.255 host 172.16.16.50
access-list 101 deny   tcp host 10.0.1.30 eq www any
access-list 101 deny   tcp host 10.0.1.30 eq 3389 any
access-list 101 deny   ip host 10.0.1.20 any
access-list 101 deny   tcp host 10.0.0.122 eq 3389 any
access-list 101 deny   tcp host 10.0.0.170 eq pop3 any
access-list 101 deny   tcp host 10.0.0.100 eq smtp any
access-list 101 deny   tcp host 10.0.0.100 eq pop3 any
access-list 101 deny   tcp host 10.0.0.170 eq 443 any
access-list 101 deny   tcp host 10.0.0.121 eq 3839 any
access-list 101 deny   tcp host 10.0.0.121 eq 9999 any
access-list 101 deny   tcp host 10.0.0.170 eq smtp any
access-list 101 deny   ip 10.0.0.0 0.0.3.255 172.16.16.0 0.0.0.255
access-list 101 permit ip 10.0.0.0 0.0.3.255 any
access-list 102 remark CCP_ACL Category=2
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.50
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.49
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.48
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.47
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.46
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.45
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.44
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.43
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.42
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.41
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.40
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.39
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.38
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.37
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.36
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.35
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.34
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.33
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.32
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.31
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.30
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.29
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.28
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.27
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.26
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.25
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.24
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.23
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.22
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.21
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.20
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.19
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.18
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.17
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.16
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.15
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.14
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.13
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.12
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.11
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.10
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.9
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.8
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.7
access-list 102 deny   ip host 10.0.0.121 host 172.16.16.6
access-list 102 permit tcp host 10.0.0.121 eq 9999 any
access-list 103 remark CCP_ACL Category=2
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.50
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.49
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.48
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.47
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.46
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.45
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.44
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.43
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.42
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.41
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.40
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.39
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.38
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.37
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.36
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.35
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.34
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.33
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.32
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.31
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.30
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.29
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.28
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.27
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.26
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.25
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.24
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.23
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.22
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.21
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.20
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.19
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.18
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.17
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.16
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.15
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.14
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.13
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.12
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.11
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.10
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.9
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.8
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.7
access-list 103 deny   ip host 10.0.0.122 host 172.16.16.6
access-list 103 permit tcp host 10.0.0.122 eq 3389 any
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.50
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.49
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.48
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.47
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.46
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.45
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.44
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.43
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.42
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.41
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.40
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.39
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.38
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.37
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.36
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.35
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.34
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.33
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.32
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.31
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.30
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.29
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.28
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.27
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.26
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.25
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.24
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.23
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.22
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.21
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.20
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.19
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.18
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.17
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.16
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.15
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.14
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.13
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.12
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.11
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.10
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.9
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.8
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.7
access-list 103 deny   ip host 10.0.0.121 host 172.16.16.6
access-list 103 permit tcp host 10.0.0.121 eq 3839 any
access-list 104 remark CCP_ACL Category=2
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.50
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.49
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.48
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.47
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.46
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.45
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.44
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.43
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.42
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.41
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.40
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.39
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.38
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.37
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.36
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.35
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.34
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.33
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.32
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.31
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.30
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.29
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.28
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.27
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.26
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.25
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.24
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.23
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.22
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.21
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.20
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.19
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.18
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.17
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.16
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.15
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.14
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.13
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.12
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.11
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.10
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.9
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.8
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.7
access-list 104 deny   ip host 10.0.0.100 host 172.16.16.6
access-list 104 permit tcp host 10.0.0.100 eq pop3 any
access-list 105 remark CCP_ACL Category=2
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.50
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.49
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.48
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.47
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.46
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.45
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.44
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.43
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.42
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.41
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.40
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.39
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.38
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.37
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.36
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.35
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.34
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.33
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.32
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.31
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.30
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.29
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.28
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.27
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.26
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.25
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.24
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.23
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.22
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.21
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.20
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.19
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.18
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.17
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.16
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.15
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.14
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.13
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.12
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.11
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.10
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.9
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.8
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.7
access-list 105 deny   ip host 10.0.0.170 host 172.16.16.6
access-list 105 permit tcp host 10.0.0.170 eq smtp any
access-list 106 remark CCP_ACL Category=2
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.50
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.49
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.48
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.47
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.46
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.45
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.44
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.43
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.42
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.41
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.40
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.39
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.38
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.37
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.36
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.35
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.34
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.33
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.32
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.31
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.30
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.29
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.28
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.27
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.26
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.25
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.24
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.23
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.22
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.21
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.20
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.19
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.18
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.17
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.16
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.15
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.14
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.13
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.12
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.11
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.10
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.9
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.8
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.7
access-list 106 deny   ip host 10.0.0.170 host 172.16.16.6
access-list 106 permit tcp host 10.0.0.170 eq 443 any
access-list 107 remark CCP_ACL Category=2
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.50
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.49
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.48
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.47
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.46
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.45
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.44
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.43
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.42
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.41
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.40
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.39
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.38
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.37
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.36
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.35
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.34
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.33
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.32
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.31
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.30
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.29
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.28
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.27
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.26
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.25
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.24
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.23
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.22
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.21
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.20
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.19
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.18
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.17
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.16
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.15
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.14
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.13
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.12
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.11
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.10
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.9
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.8
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.7
access-list 107 deny   ip host 10.0.0.170 host 172.16.16.6
access-list 107 permit tcp host 10.0.0.170 eq pop3 any
access-list 108 remark CCP_ACL Category=2
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.50
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.49
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.48
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.47
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.46
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.45
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.44
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.43
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.42
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.41
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.40
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.39
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.38
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.37
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.36
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.35
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.34
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.33
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.32
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.31
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.30
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.29
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.28
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.27
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.26
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.25
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.24
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.23
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.22
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.21
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.20
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.19
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.18
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.17
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.16
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.15
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.14
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.13
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.12
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.11
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.10
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.9
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.8
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.7
access-list 108 deny   ip host 10.0.1.20 host 172.16.16.6
access-list 108 permit ip host 10.0.1.20 any
access-list 109 remark CCP_ACL Category=2
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.50
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.49
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.48
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.47
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.46
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.45
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.44
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.43
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.42
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.41
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.40
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.39
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.38
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.37
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.36
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.35
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.34
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.33
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.32
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.31
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.30
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.29
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.28
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.27
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.26
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.25
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.24
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.23
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.22
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.21
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.20
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.19
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.18
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.17
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.16
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.15
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.14
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.13
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.12
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.11
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.10
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.9
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.8
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.7
access-list 109 deny   ip host 10.0.1.30 host 172.16.16.6
access-list 109 permit tcp host 10.0.1.30 eq 3389 any
access-list 110 remark CCP_ACL Category=17
access-list 110 permit ip host 172.16.16.1 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.2 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.3 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.4 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.5 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.6 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.7 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.8 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.9 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.10 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.11 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.12 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.13 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.14 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.15 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.16 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.17 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.18 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.19 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.20 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.21 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.22 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.23 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.24 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.25 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.26 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.27 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.28 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.29 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.30 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.31 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.32 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.33 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.34 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.35 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.36 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.37 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.38 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.39 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.40 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.41 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.42 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.43 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.44 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.45 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.46 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.47 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.48 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.49 10.0.0.0 0.0.3.255
access-list 110 permit ip host 172.16.16.50 10.0.0.0 0.0.3.255
access-list 110 permit udp any host XXX.XXX.XXX.41 eq non500-isakmp
access-list 110 permit udp any host XXX.XXX.XXX.41 eq isakmp
access-list 110 permit esp any host XXX.XXX.XXX.41
access-list 110 permit ahp any host XXX.XXX.XXX.41
access-list 110 permit esp any any
access-list 110 permit udp any any eq isakmp
access-list 110 permit udp any any eq non500-isakmp
access-list 110 permit icmp any any echo-reply
access-list 110 permit tcp any any established
access-list 110 permit tcp any host XXX.XXX.XXX.42 eq smtp
access-list 110 permit tcp any host XXX.XXX.XXX.43 eq smtp
access-list 110 permit tcp any host XXX.XXX.XXX.42 eq pop3
access-list 110 permit tcp any host XXX.XXX.XXX.43 eq pop3
access-list 110 permit tcp any host XXX.XXX.XXX.42 eq 443
access-list 110 permit tcp any host XXX.XXX.XXX.42 eq www
access-list 110 permit tcp any host XXX.XXX.XXX.42 eq 3389 log
access-list 110 permit tcp any host XXX.XXX.XXX.45 eq www
access-list 110 permit tcp any host XXX.XXX.XXX.45 eq 3389 log
access-list 110 permit ip host 207.34.105.166 any log
access-list 110 permit ip host 96.52.128.250 any log
access-list 110 permit udp host 142.3.100.15 any eq ntp log
access-list 111 remark CCP_ACL Category=2
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.50
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.49
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.48
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.47
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.46
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.45
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.44
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.43
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.42
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.41
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.40
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.39
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.38
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.37
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.36
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.35
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.34
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.33
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.32
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.31
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.30
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.29
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.28
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.27
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.26
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.25
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.24
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.23
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.22
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.21
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.20
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.19
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.18
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.17
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.16
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.15
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.14
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.13
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.12
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.11
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.10
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.9
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.8
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.7
access-list 111 deny   ip host 10.0.1.30 host 172.16.16.6
access-list 111 permit tcp host 10.0.1.30 eq www any
access-list 112 remark CCP_ACL Category=2
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.50
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.49
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.48
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.47
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.46
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.45
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.44
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.43
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.42
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.41
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.40
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.39
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.38
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.37
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.36
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.35
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.34
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.33
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.32
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.31
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.30
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.29
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.28
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.27
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.26
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.25
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.24
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.23
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.22
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.21
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.20
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.19
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.18
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.17
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.16
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.15
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.14
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.13
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.12
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.11
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.10
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.9
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.8
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.7
access-list 112 deny   ip host 10.0.0.170 host 172.16.16.6
access-list 112 permit tcp host 10.0.0.170 eq www any
access-list 113 remark CCP_ACL Category=2
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.50
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.49
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.48
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.47
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.46
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.45
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.44
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.43
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.42
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.41
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.40
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.39
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.38
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.37
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.36
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.35
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.34
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.33
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.32
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.31
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.30
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.29
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.28
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.27
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.26
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.25
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.24
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.23
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.22
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.21
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.20
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.19
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.18
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.17
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.16
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.15
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.14
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.13
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.12
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.11
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.10
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.9
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.8
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.7
access-list 113 deny   ip host 10.0.1.20 host 172.16.16.6
access-list 113 permit tcp host 10.0.1.20 eq 33445 any
access-list 167 permit ip 10.0.0.0 0.0.3.255 172.16.16.0 0.0.0.255
route-map SDM_RMAP_11 permit 1
match ip address 112
route-map SDM_RMAP_10 permit 1
match ip address 111
route-map SDM_RMAP_12 permit 1
match ip address 113
route-map NAT permit 10
match ip address 101
route-map SDM_RMAP_4 permit 1
match ip address 104
route-map SDM_RMAP_5 permit 1
match ip address 105
route-map SDM_RMAP_6 permit 1
match ip address 106
route-map SDM_RMAP_7 permit 1
match ip address 107
route-map SDM_RMAP_1 permit 1
match ip address 100
route-map SDM_RMAP_2 permit 1
match ip address 102
route-map SDM_RMAP_3 permit 1
match ip address 103
route-map SDM_RMAP_8 permit 1
match ip address 108
route-map SDM_RMAP_9 permit 1
match ip address 109
