Duplicate Packets Detected on Monitoring Tool When Switches are Added to the Network
danimalrambo
Recently I discovered that when a switch is added to the network one of our monitoring tools that is pinging a group of servers in our datacenter detects duplicate replies to ICMP requests. I used SPAN and Wireshark to verify. I suspect this ia a Spanning Tree issue ( I use Rapid PVST+) but I do not understand how this occuring in my topology. I have 2 65Ks (no VSS) at the core of my network. 1 is Root Bridge and the Other is Secondary or failover Root Bridge. Access switches are dual honed to the 65Ks with the uplink to the secondary blocked with a higher port cost. When I reboot a switch or add one to the network I see duplicate ICMP replies inicating to me that there may be a brief loop open in my network and these frames are being forwarded out different directions. I'd appreciate any help I can get in identifying this issue.
Cheers!
-Danimal
BTW I'm knew to the community. This is my 1st post.
Sonugnair_2
Hello!
1) How is the new switch connected to the network.? Is it dual homed?
2) Make sure that all switches have rapid spanning tree enabled
3) Hard code primary and seconday roots for ALL vlans. Edge switches should never be root.
4) Make sure that you have all the spanning tree enhancements in configurations(loopguard,bpduguard)
5) Make sure that you have UDLD aggressive mode configured on all fiber ports
Also, how is the CPU utilizations on both core switches? Better to check the CPU history as well
Please check "show logging". Do you find any MAC flap messages? Do you see any HSRP (if it is your FHRP) related log messages?
Regards.
1) All switches are dual honed. The connection to the secondary root is assigned a higher cost.
2) Rapid Spanning Tree is enabled.
3) Root switch has hard coded priority 8192
4) I'm not currently using Root Guard, BPDU Guard.
5) UDLD is not enabled
CPU utilization and history is relatively low. I don't see any MAC flapping and no HSRP events have occurred.
Thanks!
