Port numbering on a catalyst 3560/3750X
udo.konstantin
Hi all,
Assume I had Catalyst 3560X/3750X with 24 ports. The partnumber is WS-C3560X-24P-L
I would like to how is the numbering defined if the switches have a C3KX-NM-10G installed with 4 SFP-GE-L
Maybe I think the four additional ports are 1/25 - 28 !?
Udo
DuncanM2008
Hi Udo,
I can only presume it's the same as the 3750-X which I've worked with in the past:
Your running configuration will show the below (placeholders)
GigabitEthernet1/0/25
GigabitEthernet1/0/26
GigabitEthernet1/0/27
GigabitEthernet1/0/28
TenGigabitEthernet1/1/1
TenGigabitEthernet1/1/2
The above will be there regardless of what modules you have installed as they're placeholders for when / if you do install something.
