duplicate po1
medina.bernie
Gurus, please help. i would like to remove the po1 but after doing no int po1, the 2nd po1 still show.
interface Port-channel1
 no ip address
 hold-queue 0 in
 switchport mode trunk
sns001c2811t9003#sh int description | i Po1
Po1                            down           down
Po1                            up             down
sns001c2811t9003#
chrihussey
Don't see how this is possible. On what platform does this configuration exist?
Have you tried reloading the device to see if it clear things up?
CISCO2811 Version 12.4(13r)T11
Yes i reboot same result.
here's what i found something weird.
Upon login again today: noticed that there's only one Po1
interface Loopback0
 ip address 10.10.10.10 255.255.255.255
interface FastEthernet0/0
but after shutting down.. theres 2 PO1 (i tried to removed as well but the PO1 w/ mode trunk remains)
Po1                            admin down     down
Po1                            up                    down
and the run config shows like this
 no ip address
 shutdown
 hold-queue 0 in
It is tough to find documentation but this may provide an answer. Look at the attached link, specifically the 7200 router config. The same may apply in that by defining the port-channel as a trunk you need the major interface and then the L3 sub interfaces in their respective VLANs.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/24042-158.html
Never had to do this myself, but hope it clears things up.
