Dynamic desirable port
nnn_sss22
Hello
is it good practice to configure Dynamic desirable port?
Security risk can be happen?
Please define me thanks
Philip D'Ath
I have never heard of the feature you are describing.
Can you give an example config using this feature?
Are you talking about channelling or trunking perhaps?
Hello
if we configure Dynamic desirable port then if we attached system with this port then it will make  access port and when we will attached switch with this port then it will make trunk port.
Julio E. Moisa
My personal opinion is not use that. I always recommend use explicit trunk mode. I dont think needed this command, I used it one time everything worked fine but I always prefer use trunk mode in both ends.
It works like: if Switch A's port is configured as trunk mode  and the Switch B port is configured as desirable, the link will work as trunk. The desirable is like a passive state, it will be waiting the remote port to decide how to work.
This link could be useful:
http://www.omnisecu.com/cisco-certified-network-associate-ccna/what-is-dtp-dynamic-trunking-protocol.php
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
