Cisco 6500 Switch VSS Trouble-shooting command
Tang-Suan Tan
Hi all:
I am preparing training document for Cisco 6500 series switch.
1. For trouble-shooting command for VSS, so far I have gathered below commands :
         show switch virtual
         show switch virtual dual-active summary
         show switch virtual link
         show switch virtual link counters
         show switch virtual link port-channel
         show switch virtual role
   May I have your suggestion that any other commands are useful for trouble-shooting and any command from the top is not useful?
2. For trouble-shooting on Multi-Chassis Etherchannel on Cisco 6500, I need your help to suggest any command for the trouble-shooting. Many thanks!
Warnest regards,
tangsuan
InayathUlla Sharieff
TAng,
You have almost all the commands for VSS:
Couple of other commands are:
show switch virtual
show vslp lmp counters (LMP check)
Sh vslp lmp status
Show switch virtual link port-channel
Show switch virtual role detail
Show switch virtual redundancy
Show switch virtual redundancy config-mismatch
2-
Regarding TS MEC:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1062284
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a963a9.shtml
http://www.cisco.com/en/US/docs/solutions/Enterprise/Campus/VSS30dg/VSS-dg_ch2.html
Inayath
*Plz rate all usefull posts.
TAng,
show switch virtual
Sh vslp lmp status
2-
Regarding TS MEC:
Inayath
Hi Inayath:
Thanks to your reply!
I will read the document through your link. Many thanks!
regards,
tangsuan
