E-Chassis
sundaraneedimn
HI Experts,
Can any one pls help me in below query's.
What do E-chassis mean ? How it is helpful than the normal chassis?
How to I check whether my switch is E-Chassis or not.
SMN
Sorry, in my original response i assumed you were referring to the Catalysts 6500
You can find the difference between the 3900 and 3900-e router on the following link:
http://www.cisco.com/c/en/us/products/collateral/routers/3900-series-integrated-services-routers-isr/data_sheet_c78_553924.html
You router is the E chassis because it has the following as per the doc i have referenced above:
C3900-SPE200/K9
 4 Gigabit Ethernet interfaces
Technology Package License Information for Module:'c3900e'
John
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
The -E is the enhanced chassis. It has increased power capacity. You can get more details on 6500 and 6500-e at the following link:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/prod_bulletin0900aecd8017a5e7.html
You can determine E chassis status using the following command:
show inventory
John
Hi John,
I was checking for 3925 router, but the sh inventory doesn't show it has E-Chassis.
but sh version show's some thing, can you pls let me know this rtr is E-chassis one ?
rtr-1#sh inv
NAME: "CISCO3925-CHASSIS", DESCR: "CISCO3925-CHASSIS"
PID: CISCO3925-CHASSIS , VID: V02, SN: FGL181710LY
NAME: "Cisco Services Performance Engine 200 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 200 for Cisco 3900 ISR"
PID: C3900-SPE200/K9 , VID: V05 , SN: FOC1814AJ4G
NAME: "Two-Port Fast Ethernet High Speed WAN Interface Card on Slot 0 SubSlot 0", DESCR: "Two-Port Fast Ethernet High Speed WAN Interface Card"
PID: HWIC-2FE , VID: V02 , SN: FOC19389S4D
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 3", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64 , VID: V01 , SN: FOC18161724
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC , VID: V04 , SN: QCS1803P06M
NAME: "C3900 AC Power Supply 2", DESCR: "C3900 AC Power Supply 2"
PID: PWR-3900-AC , VID: V04 , SN: QCS1803P073
rtr-1#sh ver
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.4(3)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Sun 27-Sep-15 03:51 by prod_rel_team
ROM: System Bootstrap, Version 15.1(1r)T5, RELEASE SOFTWARE (fc1)
rtr-1 uptime is 17 weeks, 1 day, 20 hours, 58 minutes
System returned to ROM by reload at 07:39:38 UTC Sat Apr 23 2016
System restarted at 07:41:54 UTC Sat Apr 23 2016
System image file is "flash0:c3900e-universalk9-mz.SPA.154-3.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE200/K9 with 1799168K/297984K bytes of memory.
Processor board ID FGL181710LY
2 FastEthernet interfaces
DRAM configuration is 72 bits wide with parity enabled.
256K bytes of non-volatile configuration memory.
1000944K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*1 C3900-SPE200/K9 FOC1814AJ4G
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data datak9 Permanent datak9
NtwkEss None None None
CollabPro None None None
C3900-SPE200/K9
John
