E1 Configuration for CME on 2921
hello,
i have a router 2921 with the aproprieted  voice card for E1 and licenses. I would like to know how to configure it for incoming and outcoming calls. I already configured the ephone and SIP phones for internal calls. now i just need to configure it for send and receive external calls.
This is some informations about my cenario!
Router:
IOS:   c2900-universalk9-mz.SPA.153-1.T
CME: 9.1
ISP from Brazil:
type: E1
signal: R2 Digital
Channels: 32
Phone Number Iniital: XXXX-9250 (main)
ephones-dn numbers: 9250 to 9280
Please if some one help me!
Best regards....
5 Replies 5
If your controller E1 is up an running, you must configure dial-peers to route calls:
dial-peer voice 10 pots
description OUT to PSTN
destination-pattern .T
direct-inward-dial
port 1/0:15   !### use your port number
dial-peer voice 11 voip
description IN from PSTN
translation-profile incoming XLATE_PUBLIC_NUM
destination-pattern XXXX92[5-8].   !### your pstn number
b2bua
modem passthrough nse codec g711alaw
session protocol sipv2
session target ipv4:10.0.0.1  !### CME ip address
session transport udp
incoming called-number XXXX92[5-8].
dtmf-relay rtp-nte
codec g711alaw
fax rate disable
fax protocol pass-through g711alaw
no vad
Probably you must use a translation rule to convert your public phone numbers to ephone numbers:
voice translation-rule 1
rule 1 /^XXXX92/ /92/
voice translation-profile XLATE_PUBLIC_NUM
translate called 1
Regards.
Hello, Daniele!
Thanks for help.
I did this configurations with no problems, but the incoming\outcoming calls are not works. The following situations occurs:
  1. For Incoming calls: When i call to PBX from another number, is muted and then ends after some seconds;
  2. For outcoming calls: when i try to do some call, i need to insert the number "0" before the destination number, rigth?  so i put 0 and the destination number and i received a mensage from the telcom company, that was not possible to complete the call.
I changed the lines above with my configuration, but im not sure if i did rigth. Can you help me?
direct-inward-dial
port 1/0:15 !### i changed for: port 0/0/0:0  (0/0/0 its my port and  : 0  its my ds0-group. )
destination-pattern XXXX92[5-8]. !### i changed for my number without the area code and region code, i need to insert my full number ?
b2bua
session target ipv4:10.0.0.1 !### ok, i changed without problems
incoming called-number XXXX92[5-8]. !### i changed for my number without the area code and region code, i need to insert my full number ?
dtmf-relay rtp-nte
codec g711alaw
fax rate disable
no vad
rule 1 /^XXXX92/ /92/  !### i changed for my number without the area code and region code, i need to insert my full number ?
translate called 1
Please use these commands and post the output of debug for incoming and outgoing calls:
router# term mon
router# debug vpm signal
Regards.
Thanks for answer, but i resolved this problem with the configuration bellow:
Now i just have one question..... I think that the CME is taking too long time to complete de call, around 7 seconds for local calls and 12s for another city our country. Its just happen for outcoming calls.
Is It a normal time?
voice service voip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server expires max 1200 min 300
voice register global
mode cme
source-address X.X.X.X port 5060
timeouts interdigit 4
max-dn 25
max-pool 25
load 3905 CP3905.9-2-2-0
authenticate register
timezone 19
time-format 24
hold-alert
external-ring Bellcore-dr5
tftp-path flash:
create profile sync 0093222832042964
ntp-server X.X.X.X mode unicast
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  country brazil
  double-answer
  category 2
  answer-signal group-b 1
voice-port 0/0/0:0
description Local
destination-pattern 0[1-9].......
port 0/0/0:0
dial-peer voice 12 pots
description Geral
destination-pattern 0T
port 0/0/0:0
dial-peer voice 2 pots
description Incoming Call
incoming called-number .
direct-inward-dial
port 0/0/0:0
Your dialing delay is usual.
You can try to adjust the interdigit timer and use the # at the end of the dialed number to send the call immediately.
Best Regards.
