Easiest way to upgrade OS on 2960X on a stack
steeveb12
I have tried to upgrade my 2960-x stack and i made sure apply to command " boot system switch all ..... but it's still did the upgrade to one and not the other and the one that didn't get upgraded stock in process.
balaji.bandi
Quick way with Bin file :
Take the backup config out of the box, take the maintenance window since relaod required some time
check the release notes and understand the caveats. if you upgrade higher code some time required Micro Code upgrade.
1. Download the image from cisco site
2. Copy the imave to flash1: flash2 (if you have more switches increate the number and copy)
copy tftp:imax.bin flash1:image.bin
copy tftp:imax.bin flash2:image.bin
3. check the MD5 checksum
change the boot system
boot system switch all flash:/image.bin
4. write the config
5. reload
if you have like to do archive install.
archive copy-sw /force-reload /overwrite /dest 2 1  (add more switch if required)
BB
balaji.bandi
4. write the config
5. reload
BB
Leo Laohoo
Download the TAR file from the Cisco website and use this automated command:
archive download-sw tftp://<TFTP_IP_ADDRESS>/filename.tar
IOS Upgrade on Catalyst Switches 2k, 3560/3750 - Easy as Pi
