Easy CATOS question regarding using the 'clear' command
mccmhtac1
Level 2
Level 2
ok, it's been a while since I worked with catos.
I have a switch that has several lines in the config I need to remove. This is a production switch so I cannot reboot it. I see lines in the sh config. for example:
I see this line:
set trunk 3/1 on dot1q 200,700,1006-1024
When I issue the command
CLear trunk 3/1 dot1q 200
I do a show config and then see them both:
clear trunk 3/1 1-199,201-699,701-1005,1025-4094
I need to erase / remove commands from the running config, how do I get rid of them?
thx
Richard Michael
Hello Brain,
Try using this command,
set trunk 3/1 off dot1q 200,700,1006-1024
or
clear trunk 3/1 on dot1q 200,700,1006-1024
Richard
*Rate useful posts
Richard Michael
Hello Brain,
or
Richard
*Rate useful posts
