EEM event track command missing
Kenneth Goh
Level 3
Level 3
I am trying to configure EMM but the option to configure track is missing? Please help, thanks in advanced.
6 Replies 6
Giuseppe Larosa
Hello @Kenneth Goh ,
you should provide more information to get some help
what device is involved ?
What IOS XE version is running on it ?
if you like you can post the output of
show version
Hope to help
Giuseppe
Hi @Giuseppe Larosa, the IOS XE version 17.9.5 rel fc1 is already shown in my post. This is a C9300-24T switch.
Use IPSLA directly
Or you can use
Event pattern (track down/up log message)
MHM
I need to use Event Manager Applet, not IPSLA, also as shown in post there is no option for event pattern. Please help provide screenshots so as to avoid misunderstandings.
Use eem event but I stead of track use IP sla
And pattern appear after
Event cli
MHM
ok  I apologize
see the following link about using python within EEM
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/prog/configuration/179/b_179_programmability_cg/m_179_prog_eem_python.html
it says that it should be able to perform the following actions:
  • Track Object read
  • Track Object Set
Hope to help
Giuseppe
