EEM not available on 9410 switch
Jagan1976
Hi guys,
I have two C9410R chassis and want to use EEM to schedule tftp backup.
However one of the switches have no EEM function available. It does not accept the commands.
Both are running Version 16.9.2 and both have same DNA-A license.
What could be the issue when both have the same firmware and hardware? Pls help.
Output on working switch:
SW01#sho even manager version
Embedded Event Manager Version 4.00
Component Versions:
eem: (dev10)1.1.5
eem-gold: (rel1)1.0.2
eem-call-home: (rel2)1.0.5
Event Detectors:
Name                Version   Node        Type
application         01.00     node0/0     RP
rf                  01.00     node0/0     RP
syslog              01.00     node0/0     RP
identity            01.00     node0/0     RP
mat                 01.00     node0/0     RP
neighbor-discovery  01.00     node0/0     RP
generic-xed         01.00     node0/0     RP
generic             01.00     node0/0     RP
routing             03.00     node0/0     RP
rpc                 01.00     node0/0     RP
cli                 01.00     node0/0     RP
counter             01.00     node0/0     RP
interface           01.00     node0/0     RP
ioswdsysmon         01.00     node0/0     RP
none                01.00     node0/0     RP
oir                 01.00     node0/0     RP
snmp                01.00     node0/0     RP
snmp-object         01.00     node0/0     RP
snmp-notification   01.00     node0/0     RP
timer               01.00     node0/0     RP
test                01.00     node0/0     RP
config              01.00     node0/0     RP
env                 01.00     node0/0     RP
ds                  01.00     node0/0     RP
crash               01.00     node0/0     RP
gold                01.00     node0/0     RP
nf                  01.00     node0/0     RP
ipsla               01.00     node0/0     RP
Output on non-working switch:
SW02#show event manager version
% Invalid input detected at '^' marker.
SW02#
6 Replies 6
Leo Laohoo
Check the license.
License authorized on both.
SW01#sh license sum
Smart Licensing is ENABLED
Registration:
  Status: REGISTERED
  Smart Account: XYZ
  Virtual Account: Default
  Export-Controlled Functionality: Allowed
  Last Renewal Attempt: None
  Next Renewal Attempt: Sep 22 15:32:31 2021 UTC
License Authorization:
  Status: AUTHORIZED
  Last Communication Attempt: SUCCEEDED
  Next Communication Attempt: Sep 22 15:32:48 2021 UTC
License Usage:
  License                 Entitlement tag               Count Status
  C9400 Network Advantage (advantagek9-C9400)               2 AUTHORIZED
Upgrade to a different version of 16.9.X.
balaji.bandi
they are part of SVL ? or standalone?
BB
No, they are standalones.
Can you post show run | in event from both.
BB
