EEM Script Port-Security Maximum MAC
tmbenne
Frequent Visitor
Frequent Visitor
I am completely new to EEM scripting. I was curious if anyone can provide an example script that would change the maximum mac-addresses allowed on a switchport to 2 when a Cisco phone is discovered on that port via CDP. It would also be helpful if the script would add the switchport voice vlan command as well.
Thanks in advance!
balaji.bandi
Good example you can see here : Tweak as per the requirement (try only test environment, use script only you understand - this script only for reference).
event manager applet DETECT_CDP_PHONE
event neighbor-discovery interface regexp .*GigabitEthernet.* cdp add
action 10 puts "CDP Device Type $_nd_cdp_platform detected on Interface $_nd_local_intf_name"
action 20 set result "0"
action 20.1 string equal length 13 "Phone decription*" "$_nd_cdp_platform"
action 20.2 if $_string_result eq 1
action 20.3 set result "1"
action 20.4 end
action 30.1 string equal length 13 "Phone Description*" "$_nd_cdp_platform"
action 30.2 if $_string_result eq 1
action 30.3 set result "1"
action 30.4 end
action 40 if $result eq 1
action 40.1 cli command "enable"
action 40.2 cli command "conf t"
action 40.3 cli command "interface $_nd_local_intf_name"
action 40.4 cli command "YOUR COMMAND"
action 40.5 cli command "YOUR COMMAND"
action 40.6 cli command "YOUR COMMAND"
action 40.7 cli command "YOUR COMMAND"
action 40.8 cli command "description $_nd_cdp_entry_name via EEM_CDP - $_nd_cdp_platform"
action 50 puts "Configured Interface $_nd_short_local_intf_name for PHONE $_nd_cdp_entry_name"
action 60 else
action 70 puts "CDP Neighbor not recognized as PHONE. Doing nothing."
action 99 end
BB
Georg Pauwen
I have an archived shell policy which in essence does what Balaji has posted. I tweaked it a bit to adapt it to an EEM script. It applies to Cisco IP Phones and also conferencing devices. It also configures anything Ethernet including Fast/Giga/Ten etc...
The voice vlan in action 4.5 needs to reflect your own, 20 is just an example.
event manager applet CDP_PHONE_DISCOVERY
event neighbor-discovery interface regexp .*Ethernet.* cdp add
action 1 puts "CDP Device Type $_nd_cdp_platform detected on Interface $_nd_local_intf_name"
action 2 set result "0"
action 2.1 string equal length 14 "Cisco IP Phone" "$_nd_cdp_platform"
action 2.2 if $_string_result eq 1
action 2.3 set result "1"
action 2.4 end
action 3.1 string equal length 14 "Cisco IP Confe*" "$_nd_cdp_platform"
action 3.2 if $_string_result eq 1
action 3.3 set result "1"
action 3.4 end
action 4 if $result eq 1
action 4.1 cli command "enable"
action 4.2 cli command "conf t"
action 4.3 cli command "interface $_nd_local_intf_name"
action 4.4 cli command "switchport port-security maximum 2"
action 4.5 cli command "switchport voice vlan 20"
action 5 puts "Configured Interface $_nd_short_local_intf_name for Cisco IP Phone $_nd_cdp_entry_name $_nd_cdp_platform"
action 6 else
action 7 puts "CDP Neighbor not recognized as Cisco IP Phone or conferencing device."
action 8 end
