EIGRP Advertise 2 Default Routes
Mokhalil82
Level 4
Level 4
Hi Guys
I have 2 hub sites, each with its own internet breakout. Each spoke has a tunnel to both hubs.
I want both hubs to advertise out a default route using EIGRP, but I want Hub 1 to be preferred over hub 2. But if hub 1 fails then I want the spokes to use hub2 as a failover.
Can this be achieved by using a static route at each hub site such as:
Hub1 - ip route 0.0.0.0 0.0.0.0 x.x.x.x
Hub2 - ip route 0.0.0.0 0.0.0.0 x.x.x.x 190
Then redistribute these statics into EIGRP. Will this ensure Hub1 route is preferred. Does the administrative distance value for the Hub2 static get carried over into eigrp
6 Replies 6
Mark Malone
Ye that should work i persume both routers are in the same eigrp AS and make sure your metrics are correct on the redistribution bit.Only 1 route should exist in the route table but your topolgy table should show you the backup route thats advertised with worse metric.
Il give that a shot, is there a way of instead pushing out a summary route from each site and assign a metric or AD to it?
Hello
you can set default route via a eigrp summary at interface level and apply a admin distance and even Leak specific routes
Or from a spoke perspective you can manipulate received routes for lease preferred path via acl and distance command
lots of ways just depends how much admin you like to take on in terms of managing it!
res
paul
Kind Regards
Paul
On Hubs, you can just redistribute routes and then on spokes you can change delay to prefer one route over the other.
Spoke#  int tunnel 1
              des to Hub 1
              delay 1
            [ bandwith also works]
Spoke#  int tunnel 2
              des to Hub 2
             delay 100000
in this way, all routes from Hub1 are prefered.
I hope I understood your question correctly.
Masoud
Hello
Just like to add that I am not sure this will work on the admin distances of external routes I think can only be changed through K value metric!
Something like this should work:
Hub1
router eigrp xxx
redistribute static metric 2 1 1 1 1  <--------------preference
Hub2
router eigrp xxx
redistribute static metric 1 2 1 1 1
res
Paul
Kind Regards
Paul
Jon Marshall
Edit - Paul's solution of just using two default routes ie. no AD and manipulating the metric when redistributing may well be the answer but it's still not entirely clear how you see this working.
Jon
