02-29-2012 08:10 PM - edited 03-07-2019 05:16 AM
I am having two small issues....
First on my
3745 i get the following message:
*Mar 2 12:13:13.615: IP-EIGRP(Default-IP-Routing-Table:1): Neighbor 192.168.3.1 not on common subnet for FastEthernet0/1
*Mar 2 12:13:25.811: IP-EIGRP(Default-IP-Routing-Table:1): Neighbor 192.168.2.1 not on common subnet for FastEthernet0/1
Second problem is that I have my internet connection going to the 3640 on FE0/0 and it works just fine....I want to change over and have the 3745 be the internet router, but when I configure it, I get no connection.
3745 -
Current configuration : 1624 bytes
version 12.4
hostname 3745-Internet
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.150
ip dhcp pool 192.168.1.0/24
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.2.127 192.168.2.128 8.8.8.8 127.0.0.1
ip domain name www.jkkcc.com
ip name-server 192.168.2.127
ip name-server 192.168.2.128
username woodjl1650 privilege 15 password 0 henry999
archive
log config
hidekeys
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
ip address 10.0.1.6 255.255.255.252
no fair-queue
clock rate 2000000
interface FastEthernet0/1
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
router eigrp 1
network 10.0.0.0
network 192.168.1.0
no auto-summary
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 15 interface FastEthernet0/0 overload
access-list 15 permit 192.168.1.0 0.0.0.255
snmp-server community public RO
snmp-server community private RW
snmp-server enable traps tty
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
webvpn cef
end
3640 -
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname 3640-Internet
boot system flash c3640-ik9s-mz.122-40a.bin
memory-size iomem 25
ip subnet-zero
ip cef
ip domain-name www.jkkcc.com
ip dhcp excluded-address 192.168.2.1 192.168.2.150
ip dhcp pool 192.168.2.0/24
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
call rsvp-sync
ip address dhcp
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
ip address 10.0.1.9 255.255.255.252
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
ip address 10.0.1.5 255.255.255.252
interface Ethernet1/0
ip address 192.168.4.10 255.255.255.252
half-duplex
interface Ethernet1/1
no ip address
shutdown
half-duplex
interface Ethernet3/0
no ip address
shutdown
half-duplex
interface Ethernet3/1
no ip address
shutdown
half-duplex
router eigrp 1
network 10.0.0.0
network 192.168.0.0
network 192.168.2.0
no auto-summary
ip nat inside source static tcp 192.168.2.128 80 interface FastEthernet0/0 80
ip nat inside source static tcp 192.168.2.128 25 interface FastEthernet0/0 25
ip classless
ip http server
access-list 15 permit 192.168.2.0 0.0.0.255
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
2610 -
version 12.3
hostname Router
boot-start-marker
boot system flash
boot-end-marker
no logging on
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.3.1 192.168.3.150
ip dhcp pool 192.168.3.0/24
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
interface Ethernet0/0
ip address 192.168.3.1 255.255.255.0
half-duplex
interface Serial0/0
ip address 10.0.1.10 255.255.255.252
clock rate 2000000
interface Serial0/1
no ip address
shutdown
router eigrp 1
network 10.0.0.0
network 192.168.3.0
no auto-summary
no ip http server
ip classless
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
Thanks in advance for the help....
03-01-2012 12:24 AM
Hi Jon,
The first issue with EIGRP complaining about its neighbors not being on the same subnet is obvious: the problem is here indicated very clearly. You have connected three routers on a common network but their IP addresses are not from a single common subnet. Correctly, the 3745 should be 192.168.1.1/24, the 3640 should be 192.168.1.2/24 and the 2610 should be192.168.1.3/24 - or any other addressing where all three routers use IP addresses from a single common subnet.
Regarding the issues with internet connectivity - it is not clear where the PCs are connected, where is the internet access located, and what address space the clients use. Can you update the picture with this information?
Best regards,
Peter
03-01-2012 06:19 AM
Ok, I think I changed the IP scheme correctly. My question is no what router will be the devices get there IP address from? I had each router on a different subnet to act like seperate router for each network. Each router was/is connected to each other by serial connection and I was able to ping and access them that way. I still can, but now I have different IP address. I guess I am a little confused on what router will issue IP address. Since they have the same subnet are they still seperate routers and have their own pool to release IP address?
Running configs:
3640-Internet#show run
Building configuration...
Current configuration : 1851 bytes
version 12.2
ip subnet-zero
ip cef
call rsvp-sync
ip address dhcp
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
half-duplex
no ip address
shutdown
half-duplex
no ip address
shutdown
half-duplex
no ip address
shutdown
half-duplex
router eigrp 1
network 10.0.0.0
network 192.168.2.0
no auto-summary
ip classless
ip http server
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
3745-Internet#show run
Current configuration : 1614 bytes
version 12.4
boot-start-marker
boot-end-marker
no logging on
no aaa new-model
ip cef
ip dhcp pool 192.168.2.3/24
default-router 192.168.2.3
archive
log config
hidekeys
ip address dhcp
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
no fair-queue
clock rate 2000000
ip address 192.168.2.3 255.255.255.0
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
router eigrp 1
network 10.0.0.0
network 192.168.2.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 192.168.2.1
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
webvpn cef
end
Router#show run
Current configuration : 1019 bytes
version 12.3
hostname Router
boot-start-marker
boot system flash
boot-end-marker
no logging on
no aaa new-model
ip subnet-zero
ip cef
ip dhcp pool 192.168.2.4/24
ip dhcp pool 192.168.3.1
default-router 192.168.2.4
ip address 192.168.2.4 255.255.255.0
half-duplex
interface Serial0/0
clock rate 2000000
interface Serial0/1
no ip address
shutdown
router eigrp 1
network 10.0.0.0
network 192.168.2.0
no auto-summary
no ip http server
ip classless
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
03-01-2012 01:28 AM
Jon ,
As per Peter's suggestion we need to correct the network ip addressing. To become Eigrp neighbor we need to have a single common subnet. Once that being corrected , look into the Eigrp process for 2610 ...once you decide the common subnet , that needs to be advertised here as well...
Looking forward...
Hriday
03-01-2012 04:43 AM
I have a couple of things that I notice and hope tht Jonathan may clarify for us.
- I do not see any of the routers with a configured default route. So how are the routers learning a default route?
- what are you doing to switch the internet connection from the 3640 to the 3745?
- both the 3640 and the 3745 have configured address translation. But each of them uses an access list to control the translation that permits only a single locally connected network. How is internet working if the addresses are not translated?
Rick
03-01-2012 06:22 AM
From what was said above, I changed the IP Scheme so that all routers are on the same subnet. To answer the question how I am moving the internet from the 3640 to the 3745, I configured the FE0/0 on the 3745 the same way it is configured on the 3640 and moved the ethernet cable the the 3745...but no connection.
03-01-2012 09:54 AM
Jonathan
What is the router connecting to on its Fe0/0? I have seen some situations, particularly with things like cable modems, where they do not like to change connected devices and sometimes we need to power cycle the cable modem to get it to work with a new connection. Perhaps your problem is something like that?
Rick
