EIGRP flapping
awojtowicz
Level 2
Level 2
i have a nexus 9504 as a core switch and 3850's in one of our schools.  my connection between these two are always going up and down.  i get Dual-5-NBRCHANGE EIGRP-ipv4 100 neighbor 192.168.254.13 is down: interface peer-termination received then i get Dual-5-NBRCHANGE EIGRP-ipv4 100 neighbor 192.168.254.13 is up: new adjacency on my 3850.  plus i see ports going up and down.
im having problems between the buildings.
here is show log
Log Buffer (4096 bytes):
38: Power granted
Oct 8 09:26:25.351: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/38, changed state to up
Oct 8 09:26:26.352: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/38, changed state to up
Oct 8 09:26:55.977: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/38, changed state to down
Oct 8 09:26:56.982: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/38, changed state to down
Oct 8 09:26:59.646: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/38, changed state to up
Oct 8 09:27:00.646: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/38, changed state to up
Oct 8 09:35:35.805: %PLATFORM-4-ELEMENT_WARNING:Switch 2 R0/0: smand: 2/RP/0: crashinfo: usage has returned to appropriate level. value 31% (75 MB) is below warning level 80% (194 MB)
Oct 8 09:39:51.298: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.254.13 (TenGigabitEthernet2/1/4) is down: Interface PEER-TERMINATION received
Oct 8 09:39:51.307: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.254.13 (TenGigabitEthernet2/1/4) is up: new adjacency
Oct 8 09:40:35.805: %PLATFORM-4-ELEMENT_WARNING:Switch 2 R0/0: smand: 2/RP/0: limited space - copy corefiles/switch-reports out of flash:core & crashinfo: directories. crashinfo: value 84% (203 MB) exceeds warning level 80% (194 MB)
Oct 8 09:53:14.018: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to down
Oct 8 09:53:15.022: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/29, changed state to down
Oct 8 09:53:37.919: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/29, changed state to up
Oct 8 09:53:38.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to up
Oct 8 09:53:42.533: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to down
Oct 8 09:53:43.540: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/29, changed state to down
Oct 8 09:53:48.125: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/29, changed state to up
Oct 8 09:53:50.521: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/29, changed state to down
Oct 8 09:54:00.833: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/29, changed state to up
Oct 8 09:54:01.833: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to up
Oct 8 09:54:08.213: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to down
Oct 8 09:54:09.377: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/29, changed state to down
Oct 8 09:54:21.585: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/29, changed state to up
Oct 8 09:54:22.812: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to up
Oct 8 09:56:38.798: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.254.13 (TenGigabitEthernet2/1/4) is down: Interface PEER-TERMINATION received
Oct 8 09:56:39.816: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.254.13 (TenGigabitEthernet2/1/4) is up: new adjacency
Oct 8 10:00:35.392: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to down
Oct 8 10:00:40.770: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to up
Oct 8 10:00:42.751: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to down
Oct 8 10:00:43.864: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/29, changed state to down
Oct 8 10:00:47.052: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/29, changed state to up
Oct 8 10:00:48.129: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to up
Oct 8 10:00:52.192: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to down
Oct 8 10:00:54.285: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to up
Oct 8 10:00:58.989: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to down
Oct 8 10:01:00.993: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/29, changed state to up
23 Replies 23
Georg Pauwen
the bug below might apply. Basically it means that your flash does not have enough space...
The workaround is to configure a logging discriminator:
3650#conf t
3650(config)#logging discriminator HIDE_LOG severity drops 4 facility drops PLATFORM mnemonics drops ELEMENT_WARNING
3650(config)#logging buffered discriminator HIDE_LOG 100000
3650(config)#logging console discriminator HIDE_LOG
3650(config)#logging monitor discriminator HIDE_LOG
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvc14038/
balaji.bandi
if the Physical Link go up and down, Your  EIGRP go down, if they configured using that Interface.
how is these connection connected ? same campus ? or Provider Links ? what device is this Logs from ? how about other side ?
I also see some warning here :
BB
the connections are by fiber.  single mode LR sfp.  its all over our private fiber.  these logs are from a cisco 3850.  the other side is a nexus 9504.
How many Links connected between Nexus and 3850 here ?  how frequently this link going down ? also Hope the switch is not rebooting right ?
single mode LR 10G SFP both the sides ? can you post show config snippet from both the sides
show run interface Ether x/x ( from nexus)
show interface Ether x/x trans ( from nexus)
show run interface ten x/x ( from 3850 )
show interface ten x/x  trans( from 3850 )
BB
one link between them.  it happens every few minutes it seems.  switch is not rebooting.  but the 3850 runs real slow and even stops responding as i type commands.  yes single mode LR 10gb.  i'll get commands info in a minute to post.
sho run int eth 1/33
!Command: show running-config interface Ethernet1/33
!Running configuration last done at: Mon Sep 20 12:25:54 2021
!Time: Fri Oct 8 15:20:32 2021
version 9.3(4) Bios:version 05.40
description # old e3.29 uplink to Stillman_MDF_3850STK L3
udld disable
ip address 192.168.254.13/30
ip router eigrp 100
ip pim sparse-mode
no shutdown
HS-9504-01#
HS-9504-01#
HS-9504-01# sho int eth 1/33 trans
Ethernet1/33
transceiver is present
type is 10Gbase-LR
name is CISCO-FINISAR
part number is FTLX1474D3BCL-CS
revision is A
serial number is FNS160913UQ
nominal bitrate is 10300 MBit/sec
Link length supported for 9/125um fiber is 10 km
cisco id is 3
cisco extended id number is 4
cisco part number is 10-2457-02
cisco product id is SFP-10G-LR
cisco version id is V02
HS-9504-01#
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.10.08 11:23:17 =~=~=~=~=~=~=~=~=~=~=~=
$ sho run int ten 2/1/4
Building configuration...
Current configuration : 119 bytes
interface TenGigabitEthernet2/1/4
no switchport
ip address 192.168.254.14 255.255.255.252
ip pim sparse-mode
end
Stillman_MDF_3850STK#sho int ten 2/1/4 trans
Transceiver monitoring is disabled for all interfaces.
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
Optical Optical
Temperature Voltage Current Tx Power Rx Power
Port (Celsius) (Volts) (mA) (dBm) (dBm)
Te2/1/4 42.2 3.32 44.0 -0.6 -2.3
I will have a look the config, and  as we see the space issue try to delete crashinfo logs and see if that solve the issue ?
delete /force /recur flash:<CRASH FILES>
BB
can you post the output of:
dir flash:core
dir crashinfo:tracelogs
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.10.08 11:15:20 =~=~=~=~=~=~=~=~=~=~=~=
dir flash:core
Directory of flash:/core/
23233 drwx 4096 Jul 8 2018 23:32:13 -04:00 modules
7753 -rw- 1 Oct 8 2021 11:13:01 -04:00 .callhome
1621966848 bytes total (994238464 bytes free)
Stillman_MDF_3850STK#dir crashinfo:tracelogs
Directory of crashinfo:/tracelogs/
26427 -r-x 16376 Oct 8 2021 11:11:31 -04:00 dmesg
26432 -rw- 11 Oct 8 2021 11:11:31 -04:00 timestamp
26315 -rwx 1048576 Oct 7 2021 01:12:49 -04:00 sec_key_agent_R0-0.11717_31.20211006142803.bin
24298 -rwx 1048576 Oct 8 2021 09:34:44 -04:00 sec_key_agent_R0-0.11717_34.20211007224958.bin
26477 -rwx 1048576 Oct 5 2021 16:50:54 -04:00 sec_key_agent_R0-0.11717_28.20211005060608.bin
58722 -rwx 1048576 Oct 6 2021 14:25:31 -04:00 sec_key_agent_R0-0.11717_30.20211006034045.bin
58709 -rwx 1048576 Oct 7 2021 22:47:26 -04:00 sec_key_agent_R0-0.11717_33.20211007120239.bin
58698 -rwx 524288 Oct 8 2021 11:14:02 -04:00 fed_F0-0.16203_950800.20211008111401.bin
60778 -rwx 131072 Oct 8 2021 10:05:01 -04:00 btrace_rotate_sh_pmanlog_F0-0.13767_288.20211008085755.bin
58741 -rwx 1048576 Oct 6 2021 03:38:13 -04:00 sec_key_agent_R0-0.11717_29.20211005165326.bin
26323 -rwx 131072 Oct 8 2021 07:44:19 -04:00 btrace_rotate_sh_pmanlog_F0-0.13767_286.20211008063458.bin
24292 -rwx 131072 Sep 30 2021 17:32:16 -04:00 btrace_rotate_sh_pmanlog_R0-0.9319_2.20210928015441.bin
58699 -rwx 524288 Oct 8 2021 11:14:03 -04:00 fed_F0-0.16203_950802.20211008111403.bin
58700 -rwx 524288 Oct 8 2021 11:14:03 -04:00 fed_F0-0.16203_950801.20211008111402.bin
58701 -rwx 524288 Oct 8 2021 11:14:06 -04:00 fed_F0-0.16203_950805.20211008111404.bin
58703 -rwx 524288 Oct 8 2021 11:14:04 -04:00 fed_F0-0.16203_950803.20211008111403.bin
58704 -rwx 524288 Oct 8 2021 11:14:04 -04:00 fed_F0-0.16203_950804.20211008111404.bin
58705 -rwx 524288 Oct 8 2021 11:14:08 -04:00 fed_F0-0.16203_950807.20211008111408.bin
60781 -rwx 1048576 Oct 6 2021 19:22:00 -04:00 wcm_R0-0.14270_11.20211005140839.bin
58706 -rwx 524288 Oct 8 2021 11:14:08 -04:00 fed_F0-0.16203_950806.20211008111406.bin
58707 -rwx 524288 Oct 8 2021 11:14:17 -04:00 fed_F0-0.16203_950810.20211008111410.bin
58710 -rwx 524288 Oct 8 2021 11:14:09 -04:00 fed_F0-0.16203_950808.20211008111408.bin
58711 -rwx 524288 Oct 8 2021 11:14:10 -04:00 fed_F0-0.16203_950809.20211008111409.bin
38457 -rwx 524288 Oct 8 2021 11:14:17 -04:00 fed_F0-0.16203_950811.20211008111417.bin
38459 -rwx 524288 Oct 8 2021 11:14:18 -04:00 fed_F0-0.16203_950812.20211008111417.bin
38460 -rwx 524288 Oct 8 2021 11:14:19 -04:00 fed_F0-0.16203_950813.20211008111418.bin
38462 -rwx 524288 Oct 8 2021 11:14:21 -04:00 fed_F0-0.16203_950815.20211008111419.bin
38463 -rwx 524288 Oct 8 2021 11:14:22 -04:00 fed_F0-0.16203_950816.20211008111421.bin
38461 -rwx 524288 Oct 8 2021 11:14:19 -04:00 fed_F0-0.16203_950814.20211008111419.bin
58712 -rwx 524288 Oct 8 2021 11:14:23 -04:00 fed_F0-0.16203_950817.20211008111422.bin
58813 -rwx 524288 Oct 8 2021 11:14:23 -04:00 fed_F0-0.16203_950818.20211008111423.bin
58713 -rwx 524288 Oct 8 2021 11:14:24 -04:00 fed_F0-0.16203_950819.20211008111423.bin
58814 -rwx 524288 Oct 8 2021 11:14:24 -04:00 fed_F0-0.16203_950820.20211008111424.bin
58714 -rwx 524288 Oct 8 2021 11:14:25 -04:00 fed_F0-0.16203_950821.20211008111424.bin
58815 -rwx 524288 Oct 8 2021 11:14:44 -04:00 fed_F0-0.16203_950822.20211008111425.bin
58816 -rwx 524288 Oct 8 2021 11:14:44 -04:00 fed_F0-0.16203_950823.20211008111444.bin
58817 -rwx 524288 Oct 8 2021 11:14:45 -04:00 fed_F0-0.16203_950824.20211008111444.bin
58818 -rwx 524288 Oct 8 2021 11:14:45 -04:00 fed_F0-0.16203_950825.20211008111445.bin
58819 -rwx 524288 Oct 8 2021 11:14:46 -04:00 fed_F0-0.16203_950826.20211008111445.bin
58716 -rwx 524288 Oct 8 2021 11:14:54 -04:00 fed_F0-0.16203_950827.20211008111446.bin
58820 -rwx 524288 Oct 8 2021 11:14:55 -04:00 fed_F0-0.16203_950828.20211008111454.bin
58821 -rwx 524288 Oct 8 2021 11:14:56 -04:00 fed_F0-0.16203_950829.20211008111455.bin
58822 -rwx 524288 Oct 8 2021 11:14:56 -04:00 fed_F0-0.16203_950830.20211008111456.bin
38476 -rwx 131072 Oct 4 2021 06:00:00 -04:00 dbm_R0-0.8878_28.20210930201804.bin
38464 -rwx 524288 Oct 8 2021 11:15:10 -04:00 fed_F0-0.16203_950833.20211008111503.bin
58823 -rwx 524288 Oct 8 2021 11:14:57 -04:00 fed_F0-0.16203_950831.20211008111456.bin
58717 -rwx 524288 Oct 8 2021 11:15:11 -04:00 fed_F0-0.16203_950835.20211008111510.bin
58824 -rwx 524288 Oct 8 2021 11:15:02 -04:00 fed_F0-0.16203_950832.20211008111457.bin
58719 -rwx 524288 Oct 8 2021 11:15:10 -04:00 fed_F0-0.16203_950834.20211008111510.bin
58723 -rwx 524288 Oct 8 2021 11:15:13 -04:00 fed_F0-0.16203_950837.20211008111511.bin
58721 -rwx 524288 Oct 8 2021 11:15:11 -04:00 fed_F0-0.16203_950836.20211008111511.bin
60923 -rwx 524288 Oct 8 2021 11:15:14 -04:00 fed_F0-0.16203_950839.20211008111514.bin
60925 -rwx 524288 Oct 8 2021 11:15:16 -04:00 fed_F0-0.16203_950841.20211008111515.bin
38467 -rwx 524288 Oct 8 2021 11:15:14 -04:00 fed_F0-0.16203_950838.20211008111513.bin
58724 -rwx 524288 Oct 8 2021 11:15:23 -04:00 fed_F0-0.16203_950842.20211008111516.bin
60924 -rwx 524288 Oct 8 2021 11:15:15 -04:00 fed_F0-0.16203_950840.20211008111514.bin
58726 -rwx 524288 Oct 8 2021 11:15:24 -04:00 fed_F0-0.16203_950844.20211008111523.bin
58727 -rwx 524288 Oct 8 2021 11:15:24 -04:00 fed_F0-0.16203_950845.20211008111524.bin
58725 -rwx 524288 Oct 8 2021 11:15:23 -04:00 fed_F0-0.16203_950843.20211008111523.bin
58825 -rwx 524288 Oct 8 2021 11:15:26 -04:00 fed_F0-0.16203_950847.20211008111525.bin
58826 -rwx 524288 Oct 8 2021 11:15:26 -04:00 fed_F0-0.16203_950848.20211008111526.bin
58729 -rwx 524288 Oct 8 2021 11:15:25 -04:00 fed_F0-0.16203_950846.20211008111524.bin
26318 -rwx 131072 Oct 8 2021 10:15:56 -04:00 btrace_rotate_sh_R0-0.10613_221.20211008085302.bin
26319 -rwx 8192 Oct 8 2021 10:13:52 -04:00 reflector_R0-0.1515_3230.20211008100951.bin
58827 -rwx 524288 Oct 8 2021 11:15:27 -04:00 fed_F0-0.16203_950849.20211008111526.bin
58828 -rwx 524288 Oct 8 2021 11:15:28 -04:00 fed_F0-0.16203_950850.20211008111527.bin
58829 -rwx 524288 Oct 8 2021 11:15:28 -04:00 fed_F0-0.16203_950851.20211008111528.bin
58831 -rwx 524288 Oct 8 2021 11:15:29 -04:00 fed_F0-0.16203_950853.20211008111529.bin
58832 -rwx 524288 Oct 8 2021 11:15:30 -04:00 fed_F0-0.16203_950854.20211008111529.bin
58830 -rwx 524288 Oct 8 2021 11:15:29 -04:00 fed_F0-0.16203_950852.20211008111528.bin
58833 -rwx 524288 Oct 8 2021 11:15:31 -04:00 fed_F0-0.16203_950855.20211008111530.bin
58834 -rwx 524288 Oct 8 2021 11:15:31 -04:00 fed_F0-0.16203_950856.20211008111531.bin
38477 -rwx 1048576 Oct 5 2021 14:01:42 -04:00 wcm_R0-0.14270_10.20211004084842.bin
60926 -rwx 524288 Oct 8 2021 11:15:32 -04:00 fed_F0-0.16203_950857.20211008111531.bin
60928 -rwx 524288 Oct 8 2021 11:15:33 -04:00 fed_F0-0.16203_950859.20211008111533.bin
60927 -rwx 524288 Oct 8 2021 11:15:33 -04:00 fed_F0-0.16203_950858.20211008111532.bin
60929 -rwx 524288 Oct 8 2021 11:15:34 -04:00 fed_F0-0.16203_950860.20211008111533.bin
60930 -rwx 524288 Oct 8 2021 11:15:35 -04:00 fed_F0-0.16203_950861.20211008111534.bin
60931 -rwx 524288 Oct 8 2021 11:15:35 -04:00 fed_F0-0.16203_950862.20211008111535.bin
60933 -rwx 524288 Oct 8 2021 11:15:36 -04:00 fed_F0-0.16203_950864.20211008111536.bin
60932 -rwx 524288 Oct 8 2021 11:15:36 -04:00 fed_F0-0.16203_950863.20211008111535.bin
60935 -rwx 524288 Oct 8 2021 11:15:38 -04:00 fed_F0-0.16203_950866.20211008111537.bin
60937 -rwx 524288 Oct 8 2021 11:15:39 -04:00 fed_F0-0.16203_950868.20211008111538.bin
60934 -rwx 524288 Oct 8 2021 11:15:37 -04:00 fed_F0-0.16203_950865.20211008111536.bin
60936 -rwx 524288 Oct 8 2021 11:15:38 -04:00 fed_F0-0.16203_950867.20211008111538.bin
60940 -rwx 524288 Oct 8 2021 11:15:41 -04:00 fed_F0-0.16203_950871.20211008111540.bin
58896 -rwx 131072 Oct 6 2021 09:20:53 -04:00 dbm_R0-0.8878_29.20211004060001.bin
60938 -rwx 524288 Oct 8 2021 11:15:40 -04:00 fed_F0-0.16203_950869.20211008111539.bin
60939 -rwx 524288 Oct 8 2021 11:15:40 -04:00 fed_F0-0.16203_950870.20211008111540.bin
60943 -rwx 524288 Oct 8 2021 11:15:42 -04:00 fed_F0-0.16203_950873.20211008111541.bin
60942 -rwx 524288 Oct 8 2021 11:15:41 -04:00 fed_F0-0.16203_950872.20211008111541.bin
60944 -rwx 524288 Oct 8 2021 11:15:43 -04:00 fed_F0-0.16203_950874.20211008111542.bin
60945 -rwx 524288 Oct 8 2021 11:15:43 -04:00 fed_F0-0.16203_950875.20211008111543.bin
61072 -rwx 524288 Oct 8 2021 11:13:55 -04:00 fed_F0-0.16203_950797.20211008111351.bin
60946 -rwx 524288 Oct 8 2021 11:15:44 -04:00 fed_F0-0.16203_950876.20211008111543.bin
60948 -rwx 524288 Oct 8 2021 11:15:45 -04:00 fed_F0-0.16203_950878.20211008111545.bin
60950 -rwx 524288 Oct 8 2021 11:15:46 -04:00 fed_F0-0.16203_950880.20211008111546.bin
60947 -rwx 524288 Oct 8 2021 11:15:45 -04:00 fed_F0-0.16203_950877.20211008111544.bin
60949 -rwx 524288 Oct 8 2021 11:15:46 -04:00 fed_F0-0.16203_950879.20211008111545.bin
60951 -rwx 524288 Oct 8 2021 11:15:47 -04:00 fed_F0-0.16203_950881.20211008111546.bin
60953 -rwx 524288 Oct 8 2021 11:15:48 -04:00 fed_F0-0.16203_950882.20211008111547.bin
60955 -rwx 524288 Oct 8 2021 11:15:48 -04:00 fed_F0-0.16203_950883.20211008111548.bin
60956 -rwx 524288 Oct 8 2021 11:15:49 -04:00 fed_F0-0.16203_950884.20211008111548.bin
60957 -rwx 524288 Oct 8 2021 11:15:50 -04:00 fed_F0-0.16203_950885.20211008111549.bin
60958 -rwx 524288 Oct 8 2021 11:15:50 -04:00 fed_F0-0.16203_950886.20211008111550.bin
60960 -rwx 524288 Oct 8 2021 11:15:51 -04:00 fed_F0-0.16203_950888.20211008111551.bin
60959 -rwx 524288 Oct 8 2021 11:15:51 -04:00 fed_F0-0.16203_950887.20211008111550.bin
60963 -rwx 524288 Oct 8 2021 11:15:53 -04:00 fed_F0-0.16203_950891.20211008111553.bin
60961 -rwx 524288 Oct 8 2021 11:15:52 -04:00 fed_F0-0.16203_950889.20211008111551.bin
60962 -rwx 524288 Oct 8 2021 11:15:53 -04:00 fed_F0-0.16203_950890.20211008111552.bin
54657 -rwx 131072 Oct 7 2021 22:20:09 -04:00 btrace_rotate_sh_R0-0.10613_213.20211007205043.bin
60966 -rwx 524288 Oct 8 2021 11:15:55 -04:00 fed_F0-0.16203_950894.20211008111554.bin
26336 -rwx 131072 Oct 8 2021 11:11:31 -04:00 linux_iosd_image_pmanlog_R0-0.9835_2.20210922171251.bin
58807 -rwx 8192 Oct 8 2021 10:53:51 -04:00 reflector_R0-0.1515_3236.20211008105051.bin
60964 -rwx 524288 Oct 8 2021 11:15:54 -04:00 fed_F0-0.16203_950892.20211008111553.bin
60965 -rwx 524288 Oct 8 2021 11:15:54 -04:00 fed_F0-0.16203_950893.20211008111554.bin
60967 -rwx 524288 Oct 8 2021 11:15:56 -04:00 fed_F0-0.16203_950895.20211008111555.bin
58730 -rwx 524288 Oct 8 2021 11:15:56 -04:00 fed_F0-0.16203_950896.20211008111556.bin
58837 -rwx 524288 Oct 8 2021 11:16:07 -04:00 fed_F0-0.16203_950899.20211008111606.bin
58835 -rwx 524288 Oct 8 2021 11:16:06 -04:00 fed_F0-0.16203_950897.20211008111556.bin
58836 -rwx 524288 Oct 8 2021 11:16:06 -04:00 fed_F0-0.16203_950898.20211008111606.bin
58840 -rwx 524288 Oct 8 2021 11:16:09 -04:00 fed_F0-0.16203_950902.20211008111608.bin
58838 -rwx 524288 Oct 8 2021 11:16:08 -04:00 fed_F0-0.16203_950900.20211008111607.bin
58839 -rwx 524288 Oct 8 2021 11:16:08 -04:00 fed_F0-0.16203_950901.20211008111608.bin
58842 -rwx 524288 Oct 8 2021 11:16:10 -04:00 fed_F0-0.16203_950904.20211008111609.bin
54655 -rwx 131072 Oct 8 2021 10:55:28 -04:00 IOSRP_R0-0.10929_1480.20211008104100.bin
58841 -rwx 524288 Oct 8 2021 11:16:09 -04:00 fed_F0-0.16203_950903.20211008111609.bin
58845 -rwx 524288 Oct 8 2021 11:16:14 -04:00 fed_F0-0.16203_950907.20211008111613.bin
58843 -rwx 524288 Oct 8 2021 11:16:13 -04:00 fed_F0-0.16203_950905.20211008111610.bin
58844 -rwx 524288 Oct 8 2021 11:16:13 -04:00 fed_F0-0.16203_950906.20211008111613.bin
61013 -rwx 524288 Oct 8 2021 11:07:24 -04:00 fed_F0-0.16203_950476.20211008110723.bin
61017 -rwx 524288 Oct 8 2021 11:07:25 -04:00 fed_F0-0.16203_950478.20211008110724.bin
58846 -rwx 524288 Oct 8 2021 11:16:15 -04:00 fed_F0-0.16203_950908.20211008111614.bin
61020 -rwx 524288 Oct 8 2021 11:07:26 -04:00 fed_F0-0.16203_950479.20211008110725.bin
61022 -rwx 524288 Oct 8 2021 11:07:27 -04:00 fed_F0-0.16203_950481.20211008110726.bin
61021 -rwx 524288 Oct 8 2021 11:07:26 -04:00 fed_F0-0.16203_950480.20211008110726.bin
61024 -rwx 524288 Oct 8 2021 11:07:28 -04:00 fed_F0-0.16203_950483.20211008110728.bin
61023 -rwx 524288 Oct 8 2021 11:07:28 -04:00 fed_F0-0.16203_950482.20211008110727.bin
61025 -rwx 524288 Oct 8 2021 11:07:29 -04:00 fed_F0-0.16203_950484.20211008110728.bin
61027 -rwx 524288 Oct 8 2021 11:07:30 -04:00 fed_F0-0.16203_950486.20211008110729.bin
61026 -rwx 524288 Oct 8 2021 11:07:29 -04:00 fed_F0-0.16203_950485.20211008110729.bin
61028 -rwx 524288 Oct 8 2021 11:07:31 -04:00 fed_F0-0.16203_950487.20211008110730.bin
61030 -rwx 524288 Oct 8 2021 11:07:32 -04:00 fed_F0-0.16203_950489.20211008110731.bin
61029 -rwx 524288 Oct 8 2021 11:07:31 -04:00 fed_F0-0.16203_950488.20211008110731.bin
61032 -rwx 524288 Oct 8 2021 11:07:33 -04:00 fed_F0-0.16203_950491.20211008110733.bin
61031 -rwx 524288 Oct 8 2021 11:07:33 -04:00 fed_F0-0.16203_950490.20211008110732.bin
61033 -rwx 524288 Oct 8 2021 11:07:34 -04:00 fed_F0-0.16203_950492.20211008110733.bin
61035 -rwx 524288 Oct 8 2021 11:07:35 -04:00 fed_F0-0.16203_950494.20211008110734.bin
61034 -rwx 524288 Oct 8 2021 11:07:34 -04:00 fed_F0-0.16203_950493.20211008110734.bin
61038 -rwx 524288 Oct 8 2021 11:07:46 -04:00 fed_F0-0.16203_950496.20211008110736.bin
61036 -rwx 524288 Oct 8 2021 11:07:36 -04:00 fed_F0-0.16203_950495.20211008110735.bin
61039 -rwx 524288 Oct 8 2021 11:07:47 -04:00 fed_F0-0.16203_950497.20211008110746.bin
61041 -rwx 524288 Oct 8 2021 11:07:48 -04:00 fed_F0-0.16203_950499.20211008110747.bin
61040 -rwx 524288 Oct 8 2021 11:07:47 -04:00 fed_F0-0.16203_950498.20211008110747.bin
24315 -rwx 131072 Oct 8 2021 01:00:32 -04:00 btrace_rotate_sh_R0-0.10613_215.20211007233904.bin
61042 -rwx 524288 Oct 8 2021 11:07:49 -04:00 fed_F0-0.16203_950500.20211008110748.bin
61044 -rwx 524288 Oct 8 2021 11:07:50 -04:00 fed_F0-0.16203_950502.20211008110749.bin
61043 -rwx 524288 Oct 8 2021 11:07:49 -04:00 fed_F0-0.16203_950501.20211008110749.bin
61045 -rwx 524288 Oct 8 2021 11:07:53 -04:00 fed_F0-0.16203_950503.20211008110750.bin
61047 -rwx 524288 Oct 8 2021 11:07:54 -04:00 fed_F0-0.16203_950505.20211008110753.bin
38465 -rwx 131072 Oct 8 2021 10:09:50 -04:00 IOSRP_R0-0.10929_1477.20211008095700.bin
61046 -rwx 524288 Oct 8 2021 11:07:53 -04:00 fed_F0-0.16203_950504.20211008110753.bin
38472 -rwx 131072 Oct 7 2021 20:50:42 -04:00 btrace_rotate_sh_R0-0.10613_212.20211007192605.bin
61049 -rwx 524288 Oct 8 2021 11:07:55 -04:00 fed_F0-0.16203_950507.20211008110754.bin
61048 -rwx 524288 Oct 8 2021 11:07:54 -04:00 fed_F0-0.16203_950506.20211008110754.bin
61050 -rwx 524288 Oct 8 2021 11:08:02 -04:00 fed_F0-0.16203_950508.20211008110755.bin
61053 -rwx 524288 Oct 8 2021 11:08:03 -04:00 fed_F0-0.16203_950510.20211008110803.bin
61052 -rwx 524288 Oct 8 2021 11:08:02 -04:00 fed_F0-0.16203_950509.20211008110802.bin
61054 -rwx 524288 Oct 8 2021 11:08:04 -04:00 fed_F0-0.16203_950511.20211008110803.bin
61056 -rwx 524288 Oct 8 2021 11:08:07 -04:00 fed_F0-0.16203_950513.20211008110806.bin
61055 -rwx 524288 Oct 8 2021 11:08:06 -04:00 fed_F0-0.16203_950512.20211008110804.bin
61058 -rwx 524288 Oct 8 2021 11:08:08 -04:00 fed_F0-0.16203_950515.20211008110807.bin
61057 -rwx 524288 Oct 8 2021 11:08:07 -04:00 fed_F0-0.16203_950514.20211008110807.bin
61059 -rwx 524288 Oct 8 2021 11:08:09 -04:00 fed_F0-0.16203_950516.20211008110808.bin
61061 -rwx 524288 Oct 8 2021 11:08:10 -04:00 fed_F0-0.16203_950518.20211008110809.bin
60731 -rwx 131072 Oct 8 2021 09:56:30 -04:00 IOSRP_R0-0.10929_1476.20211008094148.bin
61060 -rwx 524288 Oct 8 2021 11:08:09 -04:00 fed_F0-0.16203_950517.20211008110809.bin
61062 -rwx 524288 Oct 8 2021 11:08:11 -04:00 fed_F0-0.16203_950519.20211008110810.bin
61064 -rwx 524288 Oct 8 2021 11:08:30 -04:00 fed_F0-0.16203_950521.20211008110829.bin
61063 -rwx 524288 Oct 8 2021 11:08:29 -04:00 fed_F0-0.16203_950520.20211008110811.bin
61066 -rwx 524288 Oct 8 2021 11:08:31 -04:00 fed_F0-0.16203_950523.20211008110830.bin
61065 -rwx 524288 Oct 8 2021 11:08:30 -04:00 fed_F0-0.16203_950522.20211008110830.bin
61067 -rwx 524288 Oct 8 2021 11:08:40 -04:00 fed_F0-0.16203_950524.20211008110831.bin
58731 -rwx 524288 Oct 8 2021 11:08:41 -04:00 fed_F0-0.16203_950526.20211008110840.bin
26313 -rwx 524288 Oct 8 2021 11:08:40 -04:00 fed_F0-0.16203_950525.20211008110840.bin
38542 -rwx 131072 Oct 8 2021 05:21:45 -04:00 btrace_rotate_sh_pmanlog_F0-0.13767_284.20211008041142.bin
58732 -rwx 524288 Oct 8 2021 11:08:42 -04:00 fed_F0-0.16203_950527.20211008110841.bin
58734 -rwx 524288 Oct 8 2021 11:08:50 -04:00 fed_F0-0.16203_950529.20211008110842.bin
58733 -rwx 524288 Oct 8 2021 11:08:42 -04:00 fed_F0-0.16203_950528.20211008110842.bin
58735 -rwx 524288 Oct 8 2021 11:08:54 -04:00 fed_F0-0.16203_950530.20211008110850.bin
58736 -rwx 524288 Oct 8 2021 11:08:55 -04:00 fed_F0-0.16203_950531.20211008110855.bin
58738 -rwx 524288 Oct 8 2021 11:08:56 -04:00 fed_F0-0.16203_950533.20211008110856.bin
60751 -rwx 131072 Oct 8 2021 01:44:48 -04:00 btrace_rotate_sh_pmanlog_F0-0.13767_281.20211008003349.bin
58737 -rwx 524288 Oct 8 2021 11:08:56 -04:00 fed_F0-0.16203_950532.20211008110855.bin
58740 -rwx 524288 Oct 8 2021 11:08:58 -04:00 fed_F0-0.16203_950534.20211008110856.bin
58744 -rwx 524288 Oct 8 2021 11:08:59 -04:00 fed_F0-0.16203_950536.20211008110859.bin
58742 -rwx 524288 Oct 8 2021 11:08:59 -04:00 fed_F0-0.16203_950535.20211008110858.bin
58745 -rwx 524288 Oct 8 2021 11:09:00 -04:00 fed_F0-0.16203_950537.20211008110859.bin
58747 -rwx 524288 Oct 8 2021 11:09:07 -04:00 fed_F0-0.16203_950539.20211008110900.bin
58746 -rwx 524288 Oct 8 2021 11:09:00 -04:00 fed_F0-0.16203_950538.20211008110900.bin
58749 -rwx 524288 Oct 8 2021 11:09:09 -04:00 fed_F0-0.16203_950541.20211008110908.bin
58748 -rwx 524288 Oct 8 2021 11:09:08 -04:00 fed_F0-0.16203_950540.20211008110907.bin
58750 -rwx 524288 Oct 8 2021 11:09:09 -04:00 fed_F0-0.16203_950542.20211008110909.bin
58751 -rwx 524288 Oct 8 2021 11:09:10 -04:00 fed_F0-0.16203_950543.20211008110909.bin
58753 -rwx 524288 Oct 8 2021 11:09:11 -04:00 fed_F0-0.16203_950545.20211008110911.bin
54649 -rwx 131072 Oct 8 2021 08:55:46 -04:00 IOSRP_R0-0.10929_1472.20211008084053.bin
58752 -rwx 524288 Oct 8 2021 11:09:11 -04:00 fed_F0-0.16203_950544.20211008110910.bin
54650 -rwx 131072 Oct 8 2021 08:53:01 -04:00 btrace_rotate_sh_R0-0.10613_220.20211008072853.bin
58754 -rwx 524288 Oct 8 2021 11:09:12 -04:00 fed_F0-0.16203_950546.20211008110911.bin
58755 -rwx 524288 Oct 8 2021 11:09:12 -04:00 fed_F0-0.16203_950547.20211008110912.bin
58756 -rwx 524288 Oct 8 2021 11:09:13 -04:00 fed_F0-0.16203_950548.20211008110912.bin
58758 -rwx 524288 Oct 8 2021 11:09:14 -04:00 fed_F0-0.16203_950550.20211008110914.bin
58757 -rwx 524288 Oct 8 2021 11:09:14 -04:00 fed_F0-0.16203_950549.20211008110913.bin
58760 -rwx 524288 Oct 8 2021 11:09:16 -04:00 fed_F0-0.16203_950552.20211008110915.bin
58759 -rwx 524288 Oct 8 2021 11:09:15 -04:00 fed_F0-0.16203_950551.20211008110914.bin
58761 -rwx 524288 Oct 8 2021 11:09:16 -04:00 fed_F0-0.16203_950553.20211008110916.bin
60797 -rwx 131072 Oct 7 2021 23:39:03 -04:00 btrace_rotate_sh_R0-0.10613_214.20211007222010.bin
26437 -rwx 131072 Oct 4 2021 01:25:20 -04:00 smand_R0-0.12719_1.20210926032453.bin
58762 -rwx 524288 Oct 8 2021 11:09:17 -04:00 fed_F0-0.16203_950554.20211008110916.bin
58763 -rwx 524288 Oct 8 2021 11:09:18 -04:00 fed_F0-0.16203_950555.20211008110917.bin
58765 -rwx 524288 Oct 8 2021 11:09:19 -04:00 fed_F0-0.16203_950557.20211008110918.bin
58764 -rwx 524288 Oct 8 2021 11:09:18 -04:00 fed_F0-0.16203_950556.20211008110918.bin
58766 -rwx 524288 Oct 8 2021 11:09:19 -04:00 fed_F0-0.16203_950558.20211008110919.bin
58768 -rwx 524288 Oct 8 2021 11:09:21 -04:00 fed_F0-0.16203_950560.20211008110920.bin
58767 -rwx 524288 Oct 8 2021 11:09:20 -04:00 fed_F0-0.16203_950559.20211008110919.bin
58770 -rwx 524288 Oct 8 2021 11:09:21 -04:00 fed_F0-0.16203_950561.20211008110921.bin
58772 -rwx 524288 Oct 8 2021 11:09:23 -04:00 fed_F0-0.16203_950563.20211008110922.bin
58771 -rwx 524288 Oct 8 2021 11:09:22 -04:00 fed_F0-0.16203_950562.20211008110921.bin
58773 -rwx 524288 Oct 8 2021 11:09:23 -04:00 fed_F0-0.16203_950564.20211008110923.bin
58774 -rwx 524288 Oct 8 2021 11:09:24 -04:00 fed_F0-0.16203_950565.20211008110923.bin
58775 -rwx 524288 Oct 8 2021 11:09:24 -04:00 fed_F0-0.16203_950566.20211008110924.bin
58777 -rwx 524288 Oct 8 2021 11:09:26 -04:00 fed_F0-0.16203_950568.20211008110925.bin
58776 -rwx 524288 Oct 8 2021 11:09:25 -04:00 fed_F0-0.16203_950567.20211008110924.bin
58778 -rwx 524288 Oct 8 2021 11:09:26 -04:00 fed_F0-0.16203_950569.20211008110926.bin
58780 -rwx 524288 Oct 8 2021 11:09:28 -04:00 fed_F0-0.16203_950571.20211008110927.bin
58779 -rwx 524288 Oct 8 2021 11:09:27 -04:00 fed_F0-0.16203_950570.20211008110926.bin
58782 -rwx 524288 Oct 8 2021 11:09:29 -04:00 fed_F0-0.16203_950573.20211008110928.bin
58781 -rwx 524288 Oct 8 2021 11:09:28 -04:00 fed_F0-0.16203_950572.20211008110928.bin
58783 -rwx 524288 Oct 8 2021 11:09:29 -04:00 fed_F0-0.16203_950574.20211008110929.bin
58784 -rwx 524288 Oct 8 2021 11:09:30 -04:00 fed_F0-0.16203_950575.20211008110929.bin
54659 -rwx 1048576 Oct 8 2021 00:41:58 -04:00 wcm_R0-0.14270_12.20211006192837.bin
58787 -rwx 524288 Oct 8 2021 11:09:31 -04:00 fed_F0-0.16203_950577.20211008110931.bin
58785 -rwx 524288 Oct 8 2021 11:09:31 -04:00 fed_F0-0.16203_950576.20211008110930.bin
58788 -rwx 524288 Oct 8 2021 11:09:32 -04:00 fed_F0-0.16203_950578.20211008110931.bin
58790 -rwx 524288 Oct 8 2021 11:09:33 -04:00 fed_F0-0.16203_950580.20211008110933.bin
58789 -rwx 524288 Oct 8 2021 11:09:33 -04:00 fed_F0-0.16203_950579.20211008110932.bin
58793 -rwx 524288 Oct 8 2021 11:09:34 -04:00 fed_F0-0.16203_950582.20211008110934.bin
58792 -rwx 524288 Oct 8 2021 11:09:34 -04:00 fed_F0-0.16203_950581.20211008110933.bin
58794 -rwx 524288 Oct 8 2021 11:09:35 -04:00 fed_F0-0.16203_950583.20211008110934.bin
58796 -rwx 524288 Oct 8 2021 11:09:36 -04:00 fed_F0-0.16203_950585.20211008110936.bin
58795 -rwx 524288 Oct 8 2021 11:09:36 -04:00 fed_F0-0.16203_950584.20211008110935.bin
58797 -rwx 524288 Oct 8 2021 11:09:37 -04:00 fed_F0-0.16203_950586.20211008110936.bin
58799 -rwx 524288 Oct 8 2021 11:09:38 -04:00 fed_F0-0.16203_950588.20211008110938.bin
58798 -rwx 524288 Oct 8 2021 11:09:38 -04:00 fed_F0-0.16203_950587.20211008110937.bin
58801 -rwx 524288 Oct 8 2021 11:09:39 -04:00 fed_F0-0.16203_950590.20211008110939.bin
58800 -rwx 524288 Oct 8 2021 11:09:39 -04:00 fed_F0-0.16203_950589.20211008110938.bin
58802 -rwx 524288 Oct 8 2021 11:09:40 -04:00 fed_F0-0.16203_950591.20211008110939.bin
58804 -rwx 524288 Oct 8 2021 11:09:41 -04:00 fed_F0-0.16203_950593.20211008110941.bin
24305 -rwx 131072 Oct 8 2021 08:55:57 -04:00 btrace_rotate_sh_pmanlog_F0-0.13767_287.20211008074635.bin
58803 -rwx 524288 Oct 8 2021 11:09:41 -04:00 fed_F0-0.16203_950592.20211008110940.bin
58805 -rwx 524288 Oct 8 2021 11:09:51 -04:00 fed_F0-0.16203_950594.20211008110941.bin
58808 -rwx 524288 Oct 8 2021 11:09:52 -04:00 fed_F0-0.16203_950596.20211008110951.bin
58806 -rwx 524288 Oct 8 2021 11:09:51 -04:00 fed_F0-0.16203_950595.20211008110951.bin
58809 -rwx 524288 Oct 8 2021 11:09:53 -04:00 fed_F0-0.16203_950597.20211008110952.bin
58811 -rwx 524288 Oct 8 2021 11:09:54 -04:00 fed_F0-0.16203_950599.20211008110953.bin
58810 -rwx 524288 Oct 8 2021 11:09:53 -04:00 fed_F0-0.16203_950598.20211008110953.bin
24290 -rwx 524288 Oct 8 2021 11:09:55 -04:00 fed_F0-0.16203_950601.20211008110955.bin
58812 -rwx 524288 Oct 8 2021 11:09:55 -04:00 fed_F0-0.16203_950600.20211008110954.bin
24291 -rwx 524288 Oct 8 2021 11:09:58 -04:00 fed_F0-0.16203_950602.20211008110955.bin
24294 -rwx 524288 Oct 8 2021 11:09:59 -04:00 fed_F0-0.16203_950604.20211008110958.bin
24293 -rwx 524288 Oct 8 2021 11:09:58 -04:00 fed_F0-0.16203_950603.20211008110958.bin
60868 -rwx 131072 Oct 8 2021 07:28:52 -04:00 btrace_rotate_sh_R0-0.10613_219.20211008055348.bin
38458 -rwx 131072 Oct 4 2021 02:15:36 -04:00 hman_R0-0.10820_16.20211003104744.bin
24296 -rwx 524288 Oct 8 2021 11:10:00 -04:00 fed_F0-0.16203_950605.20211008110959.bin
24299 -rwx 524288 Oct 8 2021 11:10:07 -04:00 fed_F0-0.16203_950607.20211008111007.bin
24297 -rwx 524288 Oct 8 2021 11:10:07 -04:00 fed_F0-0.16203_950606.20211008111000.bin
58715 -rwx 524288 Oct 8 2021 11:14:01 -04:00 fed_F0-0.16203_950799.20211008111401.bin
26459 -rwx 131072 Oct 2 2021 18:10:31 -04:00 hman_R0-0.10820_14.20211002025359.bin
24301 -rwx 524288 Oct 8 2021 11:10:08 -04:00 fed_F0-0.16203_950609.20211008111008.bin
24300 -rwx 524288 Oct 8 2021 11:10:08 -04:00 fed_F0-0.16203_950608.20211008111007.bin
24302 -rwx 524288 Oct 8 2021 11:10:09 -04:00 fed_F0-0.16203_950610.20211008111008.bin
24304 -rwx 524288 Oct 8 2021 11:10:12 -04:00 fed_F0-0.16203_950612.20211008111011.bin
24303 -rwx 524288 Oct 8 2021 11:10:11 -04:00 fed_F0-0.16203_950611.20211008111009.bin
60721 -rwx 524288 Oct 8 2021 11:10:13 -04:00 fed_F0-0.16203_950613.20211008111012.bin
60724 -rwx 524288 Oct 8 2021 11:10:14 -04:00 fed_F0-0.16203_950615.20211008111013.bin
60723 -rwx 524288 Oct 8 2021 11:10:13 -04:00 fed_F0-0.16203_950614.20211008111013.bin
60726 -rwx 524288 Oct 8 2021 11:10:15 -04:00 fed_F0-0.16203_950617.20211008111014.bin
60725 -rwx 524288 Oct 8 2021 11:10:14 -04:00 fed_F0-0.16203_950616.20211008111014.bin
60869 -rwx 131072 Oct 8 2021 02:27:26 -04:00 btrace_rotate_sh_R0-0.10613_216.20211008010033.bin
60727 -rwx 524288 Oct 8 2021 11:10:16 -04:00 fed_F0-0.16203_950618.20211008111015.bin
60730 -rwx 524288 Oct 8 2021 11:10:34 -04:00 fed_F0-0.16203_950620.20211008111034.bin
60728 -rwx 524288 Oct 8 2021 11:10:34 -04:00 fed_F0-0.16203_950619.20211008111016.bin
60796 -rwx 131072 Oct 8 2021 08:40:23 -04:00 IOSRP_R0-0.10929_1471.20211008082524.bin
60732 -rwx 524288 Oct 8 2021 11:10:35 -04:00 fed_F0-0.16203_950621.20211008111034.bin
60734 -rwx 524288 Oct 8 2021 11:10:38 -04:00 fed_F0-0.16203_950623.20211008111035.bin
60733 -rwx 524288 Oct 8 2021 11:10:35 -04:00 fed_F0-0.16203_950622.20211008111035.bin
60735 -rwx 524288 Oct 8 2021 11:10:45 -04:00 fed_F0-0.16203_950624.20211008111038.bin
60738 -rwx 524288 Oct 8 2021 11:10:46 -04:00 fed_F0-0.16203_950626.20211008111046.bin
60737 -rwx 524288 Oct 8 2021 11:10:46 -04:00 fed_F0-0.16203_950625.20211008111045.bin
60739 -rwx 524288 Oct 8 2021 11:10:47 -04:00 fed_F0-0.16203_950627.20211008111046.bin
60740 -rwx 524288 Oct 8 2021 11:10:50 -04:00 fed_F0-0.16203_950628.20211008111047.bin
60773 -rwx 131072 Oct 8 2021 03:51:36 -04:00 btrace_rotate_sh_R0-0.10613_217.20211008022727.bin
60741 -rwx 524288 Oct 8 2021 11:10:59 -04:00 fed_F0-0.16203_950629.20211008111051.bin
60743 -rwx 524288 Oct 8 2021 11:11:01 -04:00 fed_F0-0.16203_950631.20211008111100.bin
60742 -rwx 524288 Oct 8 2021 11:11:00 -04:00 fed_F0-0.16203_950630.20211008111059.bin
60744 -rwx 524288 Oct 8 2021 11:11:01 -04:00 fed_F0-0.16203_950632.20211008111101.bin
60746 -rwx 524288 Oct 8 2021 11:11:04 -04:00 fed_F0-0.16203_950634.20211008111103.bin
60745 -rwx 524288 Oct 8 2021 11:11:03 -04:00 fed_F0-0.16203_950633.20211008111101.bin
60850 -rwx 524288 Oct 8 2021 11:13:46 -04:00 fed_F0-0.16203_950787.20211008111345.bin
60846 -rwx 524288 Oct 8 2021 11:13:44 -04:00 fed_F0-0.16203_950785.20211008111344.bin
60851 -rwx 524288 Oct 8 2021 11:13:47 -04:00 fed_F0-0.16203_950789.20211008111346.bin
60854 -rwx 524288 Oct 8 2021 11:13:48 -04:00 fed_F0-0.16203_950790.20211008111347.bin
60853 -rwx 524288 Oct 8 2021 11:13:48 -04:00 fed_F0-0.16203_950791.20211008111348.bin
60852 -rwx 524288 Oct 8 2021 11:13:46 -04:00 fed_F0-0.16203_950788.20211008111346.bin
60857 -rwx 524288 Oct 8 2021 11:13:49 -04:00 fed_F0-0.16203_950793.20211008111349.bin
60856 -rwx 524288 Oct 8 2021 11:13:50 -04:00 fed_F0-0.16203_950794.20211008111349.bin
60855 -rwx 524288 Oct 8 2021 11:13:49 -04:00 fed_F0-0.16203_950792.20211008111348.bin
60858 -rwx 524288 Oct 8 2021 11:13:51 -04:00 fed_F0-0.16203_950795.20211008111350.bin
61071 -rwx 524288 Oct 8 2021 11:13:51 -04:00 fed_F0-0.16203_950796.20211008111351.bin
58739 -rwx 524288 Oct 8 2021 11:14:01 -04:00 fed_F0-0.16203_950798.20211008111356.bin
26348 -rwx 131072 Oct 8 2021 10:40:32 -04:00 IOSRP_R0-0.10929_1479.20211008102544.bin
60747 -rwx 524288 Oct 8 2021 11:11:04 -04:00 fed_F0-0.16203_950635.20211008111104.bin
60750 -rwx 524288 Oct 8 2021 11:11:05 -04:00 fed_F0-0.16203_950637.20211008111105.bin
60748 -rwx 524288 Oct 8 2021 11:11:05 -04:00 fed_F0-0.16203_950636.20211008111104.bin
60752 -rwx 524288 Oct 8 2021 11:11:13 -04:00 fed_F0-0.16203_950638.20211008111105.bin
60753 -rwx 524288 Oct 8 2021 11:11:13 -04:00 fed_F0-0.16203_950639.20211008111113.bin
60888 -rwx 131072 Oct 8 2021 09:10:59 -04:00 IOSRP_R0-0.10929_1473.20211008085615.bin
60756 -rwx 524288 Oct 8 2021 11:11:15 -04:00 fed_F0-0.16203_950641.20211008111114.bin
60755 -rwx 524288 Oct 8 2021 11:11:14 -04:00 fed_F0-0.16203_950640.20211008111113.bin
60757 -rwx 524288 Oct 8 2021 11:11:15 -04:00 fed_F0-0.16203_950642.20211008111115.bin
60759 -rwx 524288 Oct 8 2021 11:11:16 -04:00 fed_F0-0.16203_950644.20211008111116.bin
60758 -rwx 524288 Oct 8 2021 11:11:16 -04:00 fed_F0-0.16203_950643.20211008111115.bin
60760 -rwx 524288 Oct 8 2021 11:11:17 -04:00 fed_F0-0.16203_950645.20211008111116.bin
60761 -rwx 524288 Oct 8 2021 11:11:18 -04:00 fed_F0-0.16203_950646.20211008111117.bin
60763 -rwx 524288 Oct 8 2021 11:11:19 -04:00 fed_F0-0.16203_950648.20211008111118.bin
60762 -rwx 524288 Oct 8 2021 11:11:18 -04:00 fed_F0-0.16203_950647.20211008111118.bin
60764 -rwx 524288 Oct 8 2021 11:11:20 -04:00 fed_F0-0.16203_950649.20211008111119.bin
60766 -rwx 524288 Oct 8 2021 11:11:21 -04:00 fed_F0-0.16203_950651.20211008111120.bin
60765 -rwx 524288 Oct 8 2021 11:11:20 -04:00 fed_F0-0.16203_950650.20211008111120.bin
60768 -rwx 524288 Oct 8 2021 11:11:22 -04:00 fed_F0-0.16203_950653.20211008111121.bin
60767 -rwx 524288 Oct 8 2021 11:11:21 -04:00 fed_F0-0.16203_950652.20211008111121.bin
60770 -rwx 524288 Oct 8 2021 11:11:23 -04:00 fed_F0-0.16203_950655.20211008111123.bin
60769 -rwx 524288 Oct 8 2021 11:11:23 -04:00 fed_F0-0.16203_950654.20211008111122.bin
60771 -rwx 524288 Oct 8 2021 11:11:24 -04:00 fed_F0-0.16203_950656.20211008111123.bin
60774 -rwx 524288 Oct 8 2021 11:11:25 -04:00 fed_F0-0.16203_950658.20211008111125.bin
60772 -rwx 524288 Oct 8 2021 11:11:25 -04:00 fed_F0-0.16203_950657.20211008111124.bin
60775 -rwx 524288 Oct 8 2021 11:11:26 -04:00 fed_F0-0.16203_950659.20211008111125.bin
60776 -rwx 524288 Oct 8 2021 11:11:26 -04:00 fed_F0-0.16203_950660.20211008111126.bin
60777 -rwx 524288 Oct 8 2021 11:11:27 -04:00 fed_F0-0.16203_950661.20211008111126.bin
60779 -rwx 524288 Oct 8 2021 11:11:28 -04:00 fed_F0-0.16203_950662.20211008111127.bin
60780 -rwx 524288 Oct 8 2021 11:11:28 -04:00 fed_F0-0.16203_950663.20211008111128.bin
60783 -rwx 524288 Oct 8 2021 11:11:30 -04:00 fed_F0-0.16203_950665.20211008111129.bin
60782 -rwx 524288 Oct 8 2021 11:11:29 -04:00 fed_F0-0.16203_950664.20211008111128.bin
60785 -rwx 524288 Oct 8 2021 11:11:30 -04:00 fed_F0-0.16203_950666.20211008111130.bin
60786 -rwx 524288 Oct 8 2021 11:11:31 -04:00 fed_F0-0.16203_950667.20211008111130.bin
60787 -rwx 524288 Oct 8 2021 11:11:31 -04:00 fed_F0-0.16203_950668.20211008111131.bin
60788 -rwx 524288 Oct 8 2021 11:11:33 -04:00 fed_F0-0.16203_950670.20211008111132.bin
60789 -rwx 524288 Oct 8 2021 11:11:32 -04:00 fed_F0-0.16203_950669.20211008111131.bin
60790 -rwx 524288 Oct 8 2021 11:11:33 -04:00 fed_F0-0.16203_950671.20211008111133.bin
60791 -rwx 524288 Oct 8 2021 11:11:35 -04:00 fed_F0-0.16203_950673.20211008111134.bin
60793 -rwx 524288 Oct 8 2021 11:11:34 -04:00 fed_F0-0.16203_950672.20211008111133.bin
60794 -rwx 524288 Oct 8 2021 11:11:35 -04:00 fed_F0-0.16203_950674.20211008111135.bin
60795 -rwx 524288 Oct 8 2021 11:11:36 -04:00 fed_F0-0.16203_950676.20211008111136.bin
58702 -rwx 131072 Sep 25 2021 05:22:19 -04:00 btrace_rotate_sh_pmanlog_R0-0.9319_0.20210922205838.bin
60798 -rwx 524288 Oct 8 2021 11:11:36 -04:00 fed_F0-0.16203_950675.20211008111135.bin
60799 -rwx 524288 Oct 8 2021 11:11:37 -04:00 fed_F0-0.16203_950677.20211008111136.bin
60800 -rwx 524288 Oct 8 2021 11:11:38 -04:00 fed_F0-0.16203_950679.20211008111138.bin
60801 -rwx 524288 Oct 8 2021 11:11:38 -04:00 fed_F0-0.16203_950678.20211008111137.bin
60802 -rwx 524288 Oct 8 2021 11:11:39 -04:00 fed_F0-0.16203_950681.20211008111139.bin
60803 -rwx 524288 Oct 8 2021 11:11:39 -04:00 fed_F0-0.16203_950680.20211008111138.bin
60805 -rwx 524288 Oct 8 2021 11:11:40 -04:00 fed_F0-0.16203_950682.20211008111139.bin
60806 -rwx 524288 Oct 8 2021 11:11:41 -04:00 fed_F0-0.16203_950684.20211008111141.bin
60807 -rwx 524288 Oct 8 2021 11:11:41 -04:00 fed_F0-0.16203_950683.20211008111140.bin
60808 -rwx 524288 Oct 8 2021 11:11:42 -04:00 fed_F0-0.16203_950685.20211008111141.bin
60809 -rwx 524288 Oct 8 2021 11:11:43 -04:00 fed_F0-0.16203_950687.20211008111143.bin
60810 -rwx 524288 Oct 8 2021 11:11:43 -04:00 fed_F0-0.16203_950686.20211008111142.bin
60811 -rwx 524288 Oct 8 2021 11:11:44 -04:00 fed_F0-0.16203_950689.20211008111144.bin
60812 -rwx 524288 Oct 8 2021 11:11:44 -04:00 fed_F0-0.16203_950688.20211008111143.bin
60813 -rwx 524288 Oct 8 2021 11:11:45 -04:00 fed_F0-0.16203_950690.20211008111144.bin
60815 -rwx 524288 Oct 8 2021 11:11:46 -04:00 fed_F0-0.16203_950692.20211008111146.bin
60816 -rwx 524288 Oct 8 2021 11:11:46 -04:00 fed_F0-0.16203_950691.20211008111145.bin
60817 -rwx 524288 Oct 8 2021 11:11:47 -04:00 fed_F0-0.16203_950693.20211008111146.bin
60818 -rwx 524288 Oct 8 2021 11:11:48 -04:00 fed_F0-0.16203_950695.20211008111148.bin
60819 -rwx 524288 Oct 8 2021 11:11:48 -04:00 fed_F0-0.16203_950694.20211008111147.bin
60820 -rwx 524288 Oct 8 2021 11:11:52 -04:00 fed_F0-0.16203_950697.20211008111149.bin
60821 -rwx 524288 Oct 8 2021 11:11:49 -04:00 fed_F0-0.16203_950696.20211008111148.bin
60822 -rwx 524288 Oct 8 2021 11:11:56 -04:00 fed_F0-0.16203_950698.20211008111153.bin
60823 -rwx 524288 Oct 8 2021 11:11:57 -04:00 fed_F0-0.16203_950700.20211008111157.bin
60824 -rwx 524288 Oct 8 2021 11:11:57 -04:00 fed_F0-0.16203_950699.20211008111156.bin
60825 -rwx 524288 Oct 8 2021 11:11:58 -04:00 fed_F0-0.16203_950701.20211008111157.bin
60826 -rwx 524288 Oct 8 2021 11:11:59 -04:00 fed_F0-0.16203_950703.20211008111158.bin
60827 -rwx 524288 Oct 8 2021 11:11:58 -04:00 fed_F0-0.16203_950702.20211008111158.bin
60828 -rwx 524288 Oct 8 2021 11:12:00 -04:00 fed_F0-0.16203_950705.20211008111200.bin
60829 -rwx 524288 Oct 8 2021 11:12:00 -04:00 fed_F0-0.16203_950704.20211008111159.bin
54658 -rwx 131072 Sep 30 2021 19:00:01 -04:00 dbm_R0-0.8878_27.20210929074423.bin
60954 -rwx 131072 Oct 8 2021 09:41:20 -04:00 IOSRP_R0-0.10929_1475.20211008092631.bin
60830 -rwx 524288 Oct 8 2021 11:12:03 -04:00 fed_F0-0.16203_950706.20211008111200.bin
60831 -rwx 524288 Oct 8 2021 11:12:04 -04:00 fed_F0-0.16203_950708.20211008111203.bin
60832 -rwx 524288 Oct 8 2021 11:12:03 -04:00 fed_F0-0.16203_950707.20211008111203.bin
60833 -rwx 524288 Oct 8 2021 11:12:04 -04:00 fed_F0-0.16203_950709.20211008111204.bin
60834 -rwx 524288 Oct 8 2021 11:12:12 -04:00 fed_F0-0.16203_950711.20211008111205.bin
30383 -rwx 131072 Oct 8 2021 07:46:47 -04:00 dbm_R0-0.8878_30.20211006093023.bin
60814 -rwx 131072 Oct 3 2021 11:35:09 -04:00 btrace_rotate_sh_pmanlog_R0-0.9319_3.20210930193537.bin
60835 -rwx 524288 Oct 8 2021 11:12:05 -04:00 fed_F0-0.16203_950710.20211008111205.bin
60836 -rwx 524288 Oct 8 2021 11:12:13 -04:00 fed_F0-0.16203_950713.20211008111213.bin
60837 -rwx 524288 Oct 8 2021 11:12:13 -04:00 fed_F0-0.16203_950712.20211008111212.bin
54664 -rwx 131072 Oct 2 2021 02:20:39 -04:00 hman_R0-0.10820_13.20211001100526.bin
60838 -rwx 524288 Oct 8 2021 11:12:14 -04:00 fed_F0-0.16203_950714.20211008111213.bin
60839 -rwx 524288 Oct 8 2021 11:12:17 -04:00 fed_F0-0.16203_950716.20211008111216.bin
60840 -rwx 524288 Oct 8 2021 11:12:16 -04:00 fed_F0-0.16203_950715.20211008111214.bin
60841 -rwx 524288 Oct 8 2021 11:12:18 -04:00 fed_F0-0.16203_950718.20211008111217.bin
60842 -rwx 524288 Oct 8 2021 11:12:17 -04:00 fed_F0-0.16203_950717.20211008111217.bin
60843 -rwx 524288 Oct 8 2021 11:12:19 -04:00 fed_F0-0.16203_950719.20211008111218.bin
58791 -rwx 131072 Oct 6 2021 15:53:35 -04:00 hman_R0-0.10820_20.20211006015713.bin
60844 -rwx 524288 Oct 8 2021 11:12:20 -04:00 fed_F0-0.16203_950721.20211008111219.bin
61069 -rwx 524288 Oct 8 2021 11:12:19 -04:00 fed_F0-0.16203_950720.20211008111219.bin
61070 -rwx 524288 Oct 8 2021 11:12:21 -04:00 fed_F0-0.16203_950722.20211008111220.bin
26314 -rwx 524288 Oct 8 2021 11:12:39 -04:00 fed_F0-0.16203_950724.20211008111239.bin
30365 -rwx 131072 Sep 27 2021 07:48:28 -04:00 dbm_R0-0.8878_25.20210924080426.bin
30366 -rwx 131072 Sep 29 2021 06:11:38 -04:00 dbm_R0-0.8878_26.20210927085241.bin
60845 -rwx 524288 Oct 8 2021 11:12:39 -04:00 fed_F0-0.16203_950723.20211008111221.bin
60847 -rwx 524288 Oct 8 2021 11:12:41 -04:00 fed_F0-0.16203_950726.20211008111240.bin
60849 -rwx 524288 Oct 8 2021 11:12:40 -04:00 fed_F0-0.16203_950725.20211008111239.bin
60859 -rwx 524288 Oct 8 2021 11:12:50 -04:00 fed_F0-0.16203_950727.20211008111241.bin
60860 -rwx 524288 Oct 8 2021 11:12:51 -04:00 fed_F0-0.16203_950729.20211008111250.bin
60861 -rwx 524288 Oct 8 2021 11:12:50 -04:00 fed_F0-0.16203_950728.20211008111250.bin
60862 -rwx 524288 Oct 8 2021 11:12:52 -04:00 fed_F0-0.16203_950731.20211008111252.bin
60863 -rwx 524288 Oct 8 2021 11:12:52 -04:00 fed_F0-0.16203_950730.20211008111251.bin
60864 -rwx 524288 Oct 8 2021 11:12:58 -04:00 fed_F0-0.16203_950732.20211008111252.bin
60865 -rwx 524288 Oct 8 2021 11:13:05 -04:00 fed_F0-0.16203_950734.20211008111305.bin
60866 -rwx 524288 Oct 8 2021 11:13:05 -04:00 fed_F0-0.16203_950733.20211008111258.bin
24327 -rwx 8192 Oct 8 2021 10:06:51 -04:00 reflector_R0-0.1515_3229.20211008100251.bin
60867 -rwx 524288 Oct 8 2021 11:13:06 -04:00 fed_F0-0.16203_950735.20211008111305.bin
38466 -rwx 131072 Oct 4 2021 18:56:08 -04:00 hman_R0-0.10820_17.20211004024446.bin
60870 -rwx 524288 Oct 8 2021 11:13:06 -04:00 fed_F0-0.16203_950736.20211008111306.bin
60871 -rwx 524288 Oct 8 2021 11:13:08 -04:00 fed_F0-0.16203_950737.20211008111306.bin
60952 -rwx 131072 Oct 8 2021 09:26:11 -04:00 IOSRP_R0-0.10929_1474.20211008091128.bin
60872 -rwx 524288 Oct 8 2021 11:13:09 -04:00 fed_F0-0.16203_950738.20211008111308.bin
60873 -rwx 524288 Oct 8 2021 11:13:10 -04:00 fed_F0-0.16203_950740.20211008111309.bin
60874 -rwx 524288 Oct 8 2021 11:13:09 -04:00 fed_F0-0.16203_950739.20211008111309.bin
60875 -rwx 524288 Oct 8 2021 11:13:11 -04:00 fed_F0-0.16203_950741.20211008111310.bin
60977 -rwx 8192 Oct 8 2021 10:20:53 -04:00 reflector_R0-0.1515_3231.20211008101652.bin
30369 -rwx 131072 Oct 8 2021 10:25:15 -04:00 IOSRP_R0-0.10929_1478.20211008101019.bin
60941 -rwx 8192 Oct 8 2021 09:59:50 -04:00 reflector_R0-0.1515_3228.20211008095550.bin
61018 -rwx 131072 Oct 8 2021 10:36:03 -04:00 btrace_rotate_sh_F0-0.15751_4387.20211008103206.bin
60876 -rwx 524288 Oct 8 2021 11:13:18 -04:00 fed_F0-0.16203_950743.20211008111318.bin
60877 -rwx 524288 Oct 8 2021 11:13:18 -04:00 fed_F0-0.16203_950742.20211008111311.bin
24309 -rwx 131072 Oct 8 2021 10:32:03 -04:00 btrace_rotate_sh_F0-0.15751_4386.20211008102820.bin
58718 -rwx 131072 Oct 8 2021 10:55:25 -04:00 btrace_rotate_sh_F0-0.15751_4392.20211008105202.bin
61015 -rwx 131072 Oct 8 2021 10:39:50 -04:00 btrace_rotate_sh_F0-0.15751_4388.20211008103606.bin
24295 -rwx 131072 Oct 8 2021 00:31:33 -04:00 btrace_rotate_sh_pmanlog_F0-0.13767_280.20211007232224.bin
38502 -rwx 131072 Oct 7 2021 08:41:37 -04:00 hman_R0-0.10820_21.20211006162245.bin
61016 -rwx 8192 Oct 8 2021 09:45:49 -04:00 reflector_R0-0.1515_3226.20211008094148.bin
60754 -rwx 8192 Oct 8 2021 09:52:50 -04:00 reflector_R0-0.1515_3227.20211008094849.bin
60749 -rwx 8192 Oct 8 2021 10:39:50 -04:00 reflector_R0-0.1515_3234.20211008103755.bin
60722 -rwx 8192 Oct 8 2021 10:34:54 -04:00 reflector_R0-0.1515_3233.20211008103054.bin
61012 -rwx 131072 Oct 8 2021 10:43:09 -04:00 btrace_rotate_sh_F0-0.15751_4389.20211008104000.bin
60878 -rwx 524288 Oct 8 2021 11:13:19 -04:00 fed_F0-0.16203_950744.20211008111318.bin
60879 -rwx 524288 Oct 8 2021 11:13:20 -04:00 fed_F0-0.16203_950746.20211008111319.bin
60804 -rwx 131072 Oct 5 2021 10:57:21 -04:00 hman_R0-0.10820_18.20211004192638.bin
60848 -rwx 131072 Oct 8 2021 11:11:33 -04:00 btrace_rotate_sh_F0-0.15751_4394.20211008110736.bin
60919 -rwx 8192 Oct 8 2021 10:27:53 -04:00 reflector_R0-0.1515_3232.20211008102353.bin
24289 -rwx 1048576 Oct 7 2021 12:00:07 -04:00 sec_key_agent_R0-0.11717_32.20211007011521.bin
60880 -rwx 524288 Oct 8 2021 11:13:19 -04:00 fed_F0-0.16203_950745.20211008111319.bin
58786 -rwx 131072 Oct 7 2021 23:19:48 -04:00 btrace_rotate_sh_pmanlog_F0-0.13767_279.20211007221047.bin
61019 -rwx 0 Oct 8 2021 10:40:06 -04:00 droputil_R0-0.1545_1.20210922210510.bin
24308 -rwx 131072 Oct 8 2021 05:21:04 -04:00 btrace_rotate_sh_R0-0.10613_218.20211008035137.bin
58728 -rwx 131072 Oct 8 2021 11:15:25 -04:00 btrace_rotate_sh_F0-0.15751_4395.20211008111136.bin
61051 -rwx 131072 Oct 7 2021 23:37:39 -04:00 hman_R0-0.10820_22.20211007090907.bin
24398 -rwx 131072 Oct 8 2021 04:09:21 -04:00 btrace_rotate_sh_pmanlog_F0-0.13767_283.20211008025942.bin
60792 -rwx 131072 Oct 8 2021 10:28:13 -04:00 btrace_rotate_sh_F0-0.15751_4385.20211008102456.bin
60729 -rwx 131072 Oct 8 2021 06:32:35 -04:00 btrace_rotate_sh_pmanlog_F0-0.13767_285.20211008052344.bin
58708 -rwx 131072 Oct 8 2021 02:57:31 -04:00 btrace_rotate_sh_pmanlog_F0-0.13767_282.20211008014652.bin
60881 -rwx 524288 Oct 8 2021 11:13:21 -04:00 fed_F0-0.16203_950748.20211008111321.bin
60882 -rwx 524288 Oct 8 2021 11:13:21 -04:00 fed_F0-0.16203_950747.20211008111320.bin
60883 -rwx 524288 Oct 8 2021 11:13:23 -04:00 fed_F0-0.16203_950750.20211008111322.bin
60884 -rwx 524288 Oct 8 2021 11:13:22 -04:00 fed_F0-0.16203_950749.20211008111321.bin
60885 -rwx 524288 Oct 8 2021 11:13:23 -04:00 fed_F0-0.16203_950751.20211008111323.bin
60886 -rwx 524288 Oct 8 2021 11:13:24 -04:00 fed_F0-0.16203_950753.20211008111324.bin
60887 -rwx 524288 Oct 8 2021 11:13:24 -04:00 fed_F0-0.16203_950752.20211008111323.bin
60889 -rwx 524288 Oct 8 2021 11:13:26 -04:00 fed_F0-0.16203_950755.20211008111325.bin
60890 -rwx 524288 Oct 8 2021 11:13:25 -04:00 fed_F0-0.16203_950754.20211008111325.bin
60891 -rwx 524288 Oct 8 2021 11:13:27 -04:00 fed_F0-0.16203_950757.20211008111326.bin
60892 -rwx 524288 Oct 8 2021 11:13:26 -04:00 fed_F0-0.16203_950756.20211008111326.bin
60893 -rwx 524288 Oct 8 2021 11:13:28 -04:00 fed_F0-0.16203_950758.20211008111327.bin
60894 -rwx 524288 Oct 8 2021 11:13:28 -04:00 fed_F0-0.16203_950759.20211008111328.bin
60895 -rwx 524288 Oct 8 2021 11:13:29 -04:00 fed_F0-0.16203_950761.20211008111329.bin
60896 -rwx 524288 Oct 8 2021 11:13:29 -04:00 fed_F0-0.16203_950760.20211008111328.bin
60897 -rwx 524288 Oct 8 2021 11:13:30 -04:00 fed_F0-0.16203_950762.20211008111329.bin
60898 -rwx 524288 Oct 8 2021 11:13:31 -04:00 fed_F0-0.16203_950763.20211008111330.bin
60899 -rwx 524288 Oct 8 2021 11:13:32 -04:00 fed_F0-0.16203_950765.20211008111331.bin
60900 -rwx 524288 Oct 8 2021 11:13:31 -04:00 fed_F0-0.16203_950764.20211008111331.bin
60901 -rwx 524288 Oct 8 2021 11:13:33 -04:00 fed_F0-0.16203_950767.20211008111333.bin
60902 -rwx 524288 Oct 8 2021 11:13:33 -04:00 fed_F0-0.16203_950766.20211008111332.bin
60903 -rwx 524288 Oct 8 2021 11:13:34 -04:00 fed_F0-0.16203_950768.20211008111333.bin
60904 -rwx 524288 Oct 8 2021 11:13:34 -04:00 fed_F0-0.16203_950769.20211008111334.bin
60905 -rwx 524288 Oct 8 2021 11:13:35 -04:00 fed_F0-0.16203_950770.20211008111334.bin
60906 -rwx 524288 Oct 8 2021 11:13:36 -04:00 fed_F0-0.16203_950772.20211008111336.bin
60907 -rwx 524288 Oct 8 2021 11:13:36 -04:00 fed_F0-0.16203_950771.20211008111335.bin
60908 -rwx 524288 Oct 8 2021 11:13:37 -04:00 fed_F0-0.16203_950773.20211008111336.bin
60909 -rwx 524288 Oct 8 2021 11:13:38 -04:00 fed_F0-0.16203_950775.20211008111338.bin
60910 -rwx 524288 Oct 8 2021 11:13:38 -04:00 fed_F0-0.16203_950774.20211008111337.bin
60911 -rwx 524288 Oct 8 2021 11:13:39 -04:00 fed_F0-0.16203_950776.20211008111338.bin
60912 -rwx 524288 Oct 8 2021 11:13:40 -04:00 fed_F0-0.16203_950778.20211008111339.bin
60913 -rwx 524288 Oct 8 2021 11:13:39 -04:00 fed_F0-0.16203_950777.20211008111339.bin
60914 -rwx 524288 Oct 8 2021 11:13:41 -04:00 fed_F0-0.16203_950779.20211008111340.bin
60915 -rwx 524288 Oct 8 2021 11:13:42 -04:00 fed_F0-0.16203_950781.20211008111341.bin
60916 -rwx 524288 Oct 8 2021 11:13:41 -04:00 fed_F0-0.16203_950780.20211008111341.bin
60917 -rwx 524288 Oct 8 2021 11:13:43 -04:00 fed_F0-0.16203_950783.20211008111343.bin
60918 -rwx 524288 Oct 8 2021 11:13:43 -04:00 fed_F0-0.16203_950782.20211008111342.bin
60920 -rwx 524288 Oct 8 2021 11:13:44 -04:00 fed_F0-0.16203_950784.20211008111343.bin
60921 -rwx 524288 Oct 8 2021 11:13:45 -04:00 fed_F0-0.16203_950786.20211008111344.bin
60922 -rwx 8192 Oct 8 2021 11:00:52 -04:00 reflector_R0-0.1515_3237.20211008105752.bin
61037 -rwx 131072 Oct 8 2021 11:07:33 -04:00 btrace_rotate_sh_F0-0.15751_4393.20211008105533.bin
60784 -rwx 131072 Oct 8 2021 11:10:45 -04:00 IOSRP_R0-0.10929_1481.20211008105555.bin
61068 -rwx 8192 Oct 8 2021 11:07:53 -04:00 reflector_R0-0.1515_3238.20211008110452.bin
61078 -rwx 131072 Oct 8 2021 10:48:20 -04:00 btrace_rotate_sh_F0-0.15751_4390.20211008104330.bin
60981 -rwx 8192 Oct 8 2021 10:46:50 -04:00 reflector_R0-0.1515_3235.20211008104350.bin
54670 -rwx 131072 Oct 8 2021 10:51:51 -04:00 btrace_rotate_sh_F0-0.15751_4391.20211008104823.bin
58720 -rwx 131072 Oct 6 2021 05:34:04 -04:00 btrace_rotate_sh_pmanlog_R0-0.9319_4.20211003133119.bin
58769 -rwx 131072 Oct 3 2021 10:13:53 -04:00 hman_R0-0.10820_15.20211002183851.bin
26380 -rwx 131072 Oct 6 2021 01:26:43 -04:00 hman_R0-0.10820_19.20211005112301.bin
60736 -rwx 131072 Oct 8 2021 11:11:31 -04:00 btrace_rotate_sh_pmanlog_R0-0.9319_5.20211006073918.bin
61001 -rwx 1048576 Oct 5 2021 06:03:36 -04:00 sec_key_agent_R0-0.11717_27.20211004191850.bin
58743 -rwx 131072 Sep 27 2021 23:48:19 -04:00 btrace_rotate_sh_pmanlog_R0-0.9319_1.20210925074533.bin
248354816 bytes total (0 bytes free)
--> 248354816 bytes total (0 bytes free)
Your full is completely full. I am surprised the device is working at all. Delete all the 'fed_' files and all 'btrace' files manually.
Nexus is config as vPC and this SW is connect to one Peer.
awojtowicz
Level 2
Level 2
deleted all fed and btrace files.  still getting in show log
Oct 8 13:08:05.766: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.254.13 (TenGigabitEthernet2/1/4) is down: Interface PEER-TERMINATION received
Oct 8 13:08:10.223: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.254.13 (TenGigabitEthernet2/1/4) is up: new adjacency
Oct 8 13:12:15.850: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.254.13 (TenGigabitEthernet2/1/4) is down: Interface PEER-TERMINATION received
Oct 8 13:12:17.151: %DUAL-5-NBRCHANGE: EIGRP-IPv4 100: Neighbor 192.168.254.13 (TenGigabitEthernet2/1/4) is up: new adjacency
Can you please confirm, while the EIGRP process going down, Physical Interface up ? or down ?
If the Physical interface up, then check the MTU Settings ?
show interface ten 2/1/4 and other side same
BB
mtu both 1500.  things lag or hang when it happens.  even typing in the 3850 is real slow.  im remoting into it.
