EIGRP/IBGP recursion error routing
rioneljeudy
Community Member
How do I solve this?
Error messages:
*Mar  1 15:20:57.356: RT: recursion error routing 2.2.2.2 - probable routing loop
*Mar  1 15:20:08.912: %BGP-5-ADJCHANGE: neighbor 3.3.3.3 Down Peer closed the session
--More--
*Mar  1 15:20:21.928: RT: del 4.4.4.0/24 via 4.4.4.4, bgp metric [200/0]
*Mar  1 15:20:21.932: RT: delete subnet route to 4.4.4.0/24
*Mar  1 15:20:21.932: RT: NET-RED 4.4.4.0/24
*Mar  1 15:20:21.948: RT: Try lookup less specific 4.4.4.0/24, default 1
*Mar  1 15:20:21.948: RT: Found major net on less specific 4.0.0.0/8
My topology and configuration:
R2 interface s0/0 is connected to R4 at interface s0/0
R2 interface f0/1 is connected to R3 at interface f0/1
R3 interface s0/0 is connected to R5 at interface s0/0
R4 inteface f0/0 is connected to f0/0 at interface f0/0
R2
interface Loopback0
ip address 2.2.2.2 255.255.255.0
interface FastEthernet0/0
ip address 192.168.10.2 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 192.168.13.2 255.255.255.0
clock rate 2000000
interface FastEthernet0/1
ip address 192.168.12.2 255.255.255.0
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
router eigrp 1
network 2.2.2.0 0.0.0.255
network 192.168.12.0
network 192.168.13.0
auto-summary
router bgp 2
no synchronization
bgp log-neighbor-changes
network 2.2.2.0 mask 255.255.255.0
neighbor 3.3.3.3 remote-as 2
neighbor 3.3.3.3 update-source Loopback0
neighbor 4.4.4.4 remote-as 2
neighbor 4.4.4.4 update-source Loopback0
neighbor 192.168.10.1 remote-as 1
no auto-summary
R3
interface Loopback0
ip address 3.3.3.3 255.255.255.0
ip address 192.168.11.3 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 192.168.14.3 255.255.255.0
clock rate 2000000
ip address 192.168.12.3 255.255.255.0
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
router eigrp 1
network 3.3.3.0 0.0.0.255
network 192.168.14.0
auto-summary
router bgp 2
no synchronization
network 3.3.3.0 mask 255.255.255.0
neighbor 2.2.2.2 remote-as 2
neighbor 2.2.2.2 update-source Loopback0
neighbor 5.5.5.5 remote-as 2
neighbor 5.5.5.5 update-source Loopback0
neighbor 192.168.11.1 remote-as 1
no auto-summary
R4
interface Loopback0
ip address 4.4.4.4 255.255.255.0
ip address 192.168.15.4 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 192.168.13.4 255.255.255.0
clock rate 2000000
ip address 192.168.16.4 255.255.255.0
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
router eigrp 1
network 4.4.4.0 0.0.0.255
network 192.168.15.0
auto-summary
router bgp 2
no synchronization
network 4.4.4.0 mask 255.255.255.0
neighbor 192.168.16.6 remote-as 3
no auto-summary
R5
interface Loopback0
ip address 5.5.5.5 255.255.255.0
ip address 192.168.15.5 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 192.168.14.5 255.255.255.0
clock rate 2000000
ip address 192.168.17.5 255.255.255.0
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/2
no ip address
shutdown
clock rate 2000000
router eigrp 1
network 5.5.5.0 0.0.0.255
auto-summary
router bgp 2
no synchronization
network 5.5.5.0 mask 255.255.255.0
no auto-summary
Hello.
The issue is: you are using auto-summary under EIGRP rocess; solution - use "no auto-summary"
PS: the error says that route to neighbor was learnt over BGP itself; in scenario I would better use neighbor physical interface address than loopback.
Hello.
Gabriel Hill
Level 8
Level 8
I believe MilkailovskyVV is correct with the solution. Let me explain why I think you are seeing this. Below is your basic routing config for each router
router eigrp 1
auto-summary
router bgp 2
no synchronization
no auto-summary
Since auto-summary is on under EIGRP, the 2.2.2.0 /24 network will be auto-summarized across different major networks. It is passing between 192.168.X.X, so it will be summarizzed. Therefore, your routers will see 2.0.0.0/8.
Now here comes BGP. Your neighbors are linked to the loopback interface. In this example your 2.2.2.X Interface. Initially, your BGP comes up, but then it see's your advertisement "network 2.2.2.0 mask 255.255.255.0". Now your router will have two entries in the routing table, one from EIGRP (2.0.0.0 /8), and one for BGP (2.2.2.0 /24). Which route will it use to try and communicate with your BGP neighbor? The most specific, which happens to be advertised by the BGP neighbor. So you have the router trying to get to 2.2.2.0/24 by 2.2.2.2, this is where the recursive lookup comes from, it no longer is looking at the EIGRP route, since the one via BGP is more specific. Hope this makes sense.
-GH
