10-11-2007 03:14 PM - edited 03-05-2019 07:02 PM
I have a Router C805, only taht no support eigrp
Someone Know if the C805 can supported?
Solved! Go to Solution.
10-11-2007 03:28 PM
As per this release notes EIGRP is supported on Cisco 805. You need to have atleast an IP Plus IOS image to enable EIGRP.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/prod_release_note09186a0080087055.html
Sundar
10-11-2007 03:28 PM
Sundar
10-11-2007 07:02 PM
Ok, Thanks very much
