EIGRP over trunks
Mokhalil82
Level 7
Level 7
I need to form an EIGRP neighbor relationship between 2 x 3750 switches but they have 2 x 2960 layer 2 switches sitting in between them.
The layout is as follows.
3750---------------2960---------------2960--------------------3750
How would this be possible. Can the eigrp pass over these trunks through a vlan.
Any help will be much appreciated
9 Replies 9
Peter Paluch
Yes, absolutely. EIGRP is a protocol whose messages are encapsulated in IP packets. If there is an IP connectivity between the 3750 switches, EIGRP will run perfectly. How are you going to configure the 3750 - are you going to configure an interface Vlan with an IP address and run EIGRP on this interface, or are you going to configure routed ports from 3750 toward the 2960?
Best regards,
Peter
Thanks for the response. There are already vlans running over this trunk link so I want to create vlan interfaces on each end on the 3750's. I have setup EIGRP before but not when using Vlan interfaces.
Would the eigrp config be done in global config mode or on the vlan interfaces?
Assuming IPv4, you'll need to enable it globally on each switch and define a network statement that would match the SVI's address.
Ex:
router eigrp 1
network <SVI address> 0.0.0.0
Hi just an other question on this topic. What if there would be 2 VLANs on that trunk dat use separate EIGRP groups.
Lets say VLAN10 is advertised in EIGRP 1 and VLAN 20 is in group 2. Would that be a propper way of segmenting?
That would depend on what your requirements are. Keep two facts in mind: First, VLANs indeed separate hosts into standalone and isolated broadcast domains, but if there is a router that connects to all VLANs and each of them uses a unique IP subnet, then hosts in these VLANs can possibly communicate through the router with each other. In other words, VLANs are used to work with groups of hosts more efficiently, but they are not intended to prevent them from ever communicating to each other. Second, if two independent EIGRP processes are started on a router or a multilayer switch, they will not share any routing information unless explicitly configured to do so.
Now, if VLAN10 was advertised in EIGRP 1 and VLAN20 in EIGRP 2, then all routers running EIGRP 2 would be missing the IP subnet used in VLAN10, and vice versa, all routers running EIGRP 1 would be missing the IP subnet used in VLAN20. Consequently, hosts in VLAN10 would be unable to speak to anyone whose address is carried in EIGRP 2 (because they would not see the network in VLAN10 and would be unable to respond back), and similarly, hosts in VLAN20 would be unable to speak to anyone whose address is carried in EIGRP 1. As I indicated earlier, this may or may not be what you want to achieve.
Feel welcome to ask further!
Best regards,
Peter
Hi Peter,
Thanks for your reply. This is indeed what i would like to achieve.
I read in the requirements that the interface is actually advertised in the group due the subnet you enter. I thought that using the same interface with different subnets could cause problems when not correctly filtered.
Though if i understand you correct this is not the cause and when the subnets are not in the same EIGRP group they cannot communicate between each other? I want to use the same connection for networks that will not share traffic except the ones in the same EIGRP group.
Thanks in advance!
Gertjan
Hi Gertjan,
Can you give me an example with actual addresses please, including a description of what should be accomplished? I am somewhat lost in trying to understand how your scenario is going to look like - it's just my daftness so please bear with me 🙂
Best regards,
Peter
Hi Peter,
My appologies for the late reply and no problem.
VLAN 10 and 20 are only used for making the connections. they are actually an external L2 network. What i like to do is start with segementing the networks in the EIGRP groups but sometimes the same lines are used for the traffic.
Hope this clarifies what im trying to achieve.
EIGRP is a layer 3 protocol. Your 2960 passes EIGRP messages without having any idea about them.
As long as, your 3750 switches see each other, you do not have to be concern about 2960.
Sample
Make trunk interfaces between two 3750 and 2960 , then create interface vlans on your 3750
3750-1
Int vlan 10
192.168.1.1 250.255.255.0
3750-2
Int vlan 10
192.168.1.2 250.255.255.0
Now 3750-1 can see 3750-2  Then
3750-1 and-3750-2
Router EIGRP 1
network 192.168.1.0 255.255.255.0
Add your other networks here
Just make sure to create vlan 10 in both 2960 switches
Hope it helps,
Masoud
