EIGRP passive interface Nexus 7k
WILLIAM STEGMAN
Level 4
Level 4
There are some interfaces on the 7k, 6.2(8b). that are configured as passive, ip passive-interface eigrp 100, and those networks are not being advertised via eigrp.  It's my understanding that the passive command stops neighbor relationships from forming, but will continue to advertise the connected networks.  This appears to be the case with Nexus as it is with IOS.
From
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/4_2/nx-os/unicast/configuration/guide/l3_cli_nxos/l3_eigrp.pdf
"Configuring a Passive Interface for EIGRP You can configure a passive interface for EIGRP.
A passive interface does not participate in EIGRP adjacency but the network address for the interfacee remains in the EIGRP topology table."
What am I missing?
thank you,
Bill
Not used Nexus but as far as I am aware you still need to enable EIGRP under the interface.
So using your example above -
int vlan 3
ip router eigrp 10
ie. you need to run EIGRP on the interface but then make it passive with the additional command.
Just using the passive-interface command on it's own does not mean EIGRP runs on that interface.
Like I say not used Nexus but it seems the most logical explanation.
Jon
7 Replies 7
Reza Sharifi
Your understanding is correct. The behavior is the same for both IOS and Nexus OS.
Can you post relevant configs?
!Command: show running-config interface Vlan3
!Time: Sat Jan  2 09:06:05 2016
version 6.2(8b)
interface Vlan3
    no shutdown
  ip address 10.13.2.1/24
  ip wccp 80 redirect in
ASC7010-ASC7010-prod# sh ip eigrp neighbors
IP-EIGRP neighbors for process 10 VRF default
H   Address                 Interface       Hold  Uptime  SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
1   10.8.63.250             Po60            10   4w0d      4    50    0   252652
ASC7010-ASC7010-prod# sh ip eigrp topology 10.13.2.0 255.255.255.0
% IP-EIGRP (AS 10): Route not in topology table
ASC7010-ASC7010-prod# sh run | sec router
router eigrp 10
  distance 205 15
  default-metric 1000000 100 255 1 1500
  redistribute static route-map STATIC-TO-EIGRP
On the adjacent eigrp neigbor 10.8.63.250
ASC-DMVPN-Inet#sh ip route 10.13.2.0
% Subnet not in table
int vlan 3
ip router eigrp 10
Jon
I was tracking that same sort of rationale, but messed up the command and thought it wasn't available.
ASC7010-ASC7010-prod(config-if)# ip eigrp 10 ?
  shutdown  Shutdown EIGRP on this interface
% Incomplete command at '^' marker.
It's
interface Vlan44
  no shutdown
  ip address 10.13.8.1/24
  ip router eigrp 10
and that does in fact do the trick.  Thanks Jon.
Hi Bill,
Your not missing anything!
say on the 7k you had an interface with an address of 10.10.10.1/30 then the 10.10.10.0/30 address would be advertised by  EIGRP on the 7k, but any networks on the other end of the link would not.
Thanks Richard.  It's odd, all the interfaces configured with passive are not in the topology, but sure enough all those with the router eigrp show up.
interface Vlan6
  ip address 10.13.4.1/24
  ip router eigrp 10
    no shutdown
ASC7010-ASC7010-prod# sh ip eigrp topology 10.13.4.0 255.255.255.0
IP-EIGRP (AS 10): Topology entry for 10.13.4.0/24
  State is Passive, Query origin flag is 1, 1 Successor(s), FD is 2816
  Routing Descriptor Blocks:
  0.0.0.0 (Vlan6), from Connected, Send flag is 0x0
      Composite metric is (2816/0), Route is Internal
      Vector metric:
        Minimum bandwidth is 1000000 Kbit
        Total delay is 10 microseconds
        Reliability is 255/255
        Load is 1/255
        Minimum MTU is 1500
        Hop count is 0
        Internal tag is 0
rakeshvelagala
Level 3
Level 3
Firstly, did you advertise this network using the network or redistribute command?
