running config and voice hardware in cucm
John Cheetley
Level 3
Level 3
Hi Team,
Is there a show running config command in cucm 6.0.1 that one can use to show the current configuration of router
And how does one view/see the physical hardware connnected in CUCM 6.0.1?
Much appreciated in advance.
7 Replies 7
Hi John,
"show running configuration" and "show cdp neighbor detail" would be helpful if we are using call manager express, however in cucm we do not have such option to fetch the running configuration, but you can use "show network cluster" to get the nodes connected in a network cluster, rest is DRS procedure to copy the current working configuration and restore.
As you must be aware of the supported cucm version and bug fixes, you should be thinking of upgrading cucm to the latest supported version.
Venkatesh.
-Do rate helpful posts.
Hi Venkatesh,
Thanks for your response.
Thanks for answering the first part of the question.
Why would I need Disaster Recovery Service.
Hi John,
You can use the Import/Export menu in Cisco Unified Communications Manager Bulk Administration Tool (BAT) to export or import parts of the Cisco Unified Communications Manager database to another server, or to the same server with modifications. This reduces the configuration time that is required by importing a preconfigured database to the installed Cisco Unified Communications Manager server.
DRS would not be applicable here :)
regards,
Thanks for the response Venperum.
At the moment I can't get the router to see the switch.
Switch can ping router but not vice versa. But router can ping ISP.
Interfaces on switch are open. Same as on router (trunkport)
Firewall is off (for testing)
Hi Venperum,
Sorry for my late reply.
Busy with work
Thanks for the feedback.
What's the easiest way for CUCM to see modular hardware and gig and fa interfaces to be configured please?
Is there a link I can follow?
Hi John,
CUCM is an application deployed in  mcs/ucs environment. The hardware module, gig and fa interfaces you are talking about would be there in router or switches.
we use PVDM card/modules in ISR routers for media, which enables routers to provide high-density voice connectivity, conferencing, and transcoding capabilities in Cisco IP Communications solutions, you can refer the below link for the same.
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/product_data_sheet0900aecd8016e845.html
you can also follow the below link on CUCM basics lab topology and leanings.
http://www.learncisco.net/courses/cucm-basics/overview/lab-topology.html
regards
Thanks for the quick reply Venperum
I will have a read.  Much appreciated :) :)
